F350 worktruck will not start! - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 03-03-2008, 06:54 PM Thread Starter
Unhappy F350 worktruck will not start!
I have a F350 diesel that will not start. It has 2250 pounds of high oil pressure, 40 pounds of fuel pressure, got truck started on ether and it ran rough, started pulling injector wires and the 2 cyclinders on driver side rear weren't firing. the main wiring harness plug is okay, the valve cover gasket is new, and under the valve cover injector the wiring harness is new. When I go to start it it will crank for 15 seconds, then it'll hit for 2 seconds and then nothing.
I know it's not glo plugs, it's full of motor oil, have good oil and fuel pressure. I don't know if the main wiring harness has fire to the injectors. Everything from the main harness under the valve cover it okay. I took an OHM meter and checked the 2 dead injectors and they OHM'd the same as the 2 good injectors.
When it was running I pulled all plugs off injectors one at a time and the motor died down on all of them but on the left hand rear plug.
ANY SUGGESTIONS or IDEAS please?
gibagser is offline
post #2 of 18 (permalink) Old 03-03-2008, 07:06 PM
Excavator's Avatar
My Photos: (11)
First think I would do is put battery charger on it as it needs 10.5 volts while cranking to fire injectors.
Engine need this to start
voltage min 10.5 while cranking
rpm of 100 as cranking
icp of 0.85 or 500 psi HPOP
fuel pulse with 1 to 6 milliseconds
Are you getting tach reading of 100?
Does it no start cold and hot or just cold?
If you plug it in will it start?
How old is CPS ?
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #3 of 18 (permalink) Old 03-03-2008, 07:27 PM Thread Starter
the motor cranks fast the batterys are good.it's been pluged in since this mourning since it wouldn't start.i don't know about the tach? my wife was cranking it while i was checking the oil and fuel pressure.it ran fine sat. then mon. it woundn't start,like noglow plugsworking. but the relay is putting fire to them.the truck has 198600miles the only thing that has been replaced is the crank sensor about 50000miles ago.it does have a 65hp chip its has been in it since day one!
gibagser is offline
post #4 of 18 (permalink) Old 03-03-2008, 07:30 PM
Excavator's Avatar
My Photos: (11)
3 things to try
remove the chip and try it
replace the cps if that many miles
check the tach and wts light
Swamps,Tony Wildman
post #5 of 18 (permalink) Old 03-03-2008, 07:37 PM
fxdwgi's Avatar
The motor can crank all day long....you need 10 volts while cranking to fire injectors.
Use a DVM @ a battery to check while cranking.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
post #6 of 18 (permalink) Old 03-03-2008, 07:40 PM
Excavator's Avatar
My Photos: (11)
also check to see if you get white smoke while cranking.
How do you know glow plugs are working?
Did you ohm them out?
Did you check the GP relay with volt meter
Swamps,Tony Wildman
post #7 of 18 (permalink) Old 03-03-2008, 07:52 PM Thread Starter
no white smoke.didn't ohm relay or check battery volts!the truck will start on ether but run on 6 cyl.s what ever the problem is has to do with the rear driver side cyl.s
gibagser is offline
post #8 of 18 (permalink) Old 03-03-2008, 08:00 PM
Kanman's Avatar
Did I read this correctly, you have 2 dead injectors?
Kanman is offline
post #9 of 18 (permalink) Old 03-03-2008, 08:10 PM Thread Starter
when i unplugged the plug to the valve cover it didn't change the engine tone like the other 3 plugs did
gibagser is offline
post #10 of 18 (permalink) Old 03-04-2008, 03:09 AM
Excavator's Avatar
My Photos: (11)
No white smoke, then your injectors are not sending fuel. The IDM is not sending signal to any injectors or you would have tons of white smoke as you crank with no start. Your 2 injectors not running tells me you had the truck running but now you say not running. I would suggest you inspect that wire harness for short somewhere as if you have a short it can shut down the IDM. Now speaking of IDM you could also have water build up in the IDM and that is the reason for those 2 injectors not running. Again I ask if you have tach movement of 100 rpm?
Do you get WTS (wait to start) light?
check fuse # 22 and fuse # 9 in engine compartment
1996 Bronco/F-Series
Swamps,Tony Wildman
post #11 of 18 (permalink) Old 03-04-2008, 06:54 PM Thread Starter
i had the truck scanned today and it said computer failed error. so i took mr. bullydog out and it started and ran just like brand new!THANKS FOR ALL THE INPUT!!!!it might be slow now but atleast its hitting on all 8 again!!! THANKS AGAIN!!!!!!!!!!!!!!!!!!!
gibagser is offline
post #12 of 18 (permalink) Old 03-04-2008, 06:58 PM
Excavator's Avatar
My Photos: (11)
Thats good you are back running. Time for a better chip
Swamps,Tony Wildman
post #13 of 18 (permalink) Old 04-08-2008, 02:05 PM
Red face F350 Worktruck will not start!
I'm having the same trouble but instead getting the white smoke. Any advice would be great. No one around these parts have been able to guess what this is. I just bought the truck, the harness from the lower left area across the middle to the firewall has about 5 wires. 2 of them were melted together. Previous when I tried to start it, Often she wouldn't until i tapped on the harness - I would hear a Click and she'd start right up! Is there a switch back there, and if there is how would I fix this? You can tell I'm new with the diesel. Any ideas guys!? Thank you! This is a 1986 F350 Diesel 7.3 Flat/Dualies. ~Andrew
andrew_draper is offline
post #14 of 18 (permalink) Old 04-08-2008, 03:18 PM
The click you hear , may be the Glow plug relay ,,,you should hear it , just by turning on the key ,,,
Did you repair the wiring ?
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #15 of 18 (permalink) Old 04-08-2008, 03:23 PM
F350 Glow plug replay?
Yes repaired it with a professional electrician - pretty basic - replaced the melted sections of wire. But now it seems that the switch is switched the other way and should be switched once more to be correct? The truck tries hard to turn over, great new batteries, but never does so. thanks for help with this!
