flashing overdrive light - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 01-27-2007, 04:11 AM Thread Starter
We have a '99 Ford 350 power stroke. For no apparent reason the light on the gear shift near the overdrive on/off button starts flashing. If you stop and turn the engine off and restart, it quits. A local mechanic "says" he put it on some diagnostic computer and changed out a part to the tune of darn near 500 bucks and duh, it is still happening. We took the truck back in and they checked it again with some hand held deal and now they are saying O rings and we probably had only 30,000 miles left on that tranny. The truck has 121k miles on it. Any thoughts, suggestions or advice would be very much appreciated. We're seniors trying to make it on social security so things like transmissions scare me a bit. I have a feeling the $500 I spent was p'ing in the wind!! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
paintlady is offline
post #2 of 10 (permalink) Old 01-27-2007, 04:21 AM
Re: flashing overdrive light
I don't know what other situations it will happen in, but in my '99 the button was bad so they switched out the whole shifter and the problem was solved. On my 02 the light started flashing, but that was because I was stuck in the snow and the tranny was overheating. Does the overdrive work? Is there any situation that makes it start or stop again?
white 2002 f250 Superduty Crew Cab 7.3 liter 4x4
Thormx250 is offline
post #3 of 10 (permalink) Old 01-27-2007, 10:01 AM
Have you checked the fluid level? Is the tranny slipping at all?
1999.5 PSD, 4x4, Auto trans, 6.0 Trans cooler, Shift kit, ZooDad Mod, ISSPRO Trans - boost - EGT gauges, Wicked Wheel, Big Green Filter Intake, 4" cat back exhaust, 315 75 17 BFG AT's, ProComp 9000's at the corners, CCV Mod, Leer topper, Fumatomo Valve, Pooned tank, more goodies to come
Estonk is offline
post #4 of 10 (permalink) Old 01-27-2007, 10:24 AM
Flywheel's Avatar
If you can, post the codes that they pulled from the computer. The OD light can flash for various reasons. Also, post the part they replaced....I hope it was not the VSS.....
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #5 of 10 (permalink) Old 01-27-2007, 10:50 AM
simply have them check the upper harness over behind the flasher button on top of column for a short if they have'nt already done so. i get alot of them in here w/ that problem w/ the wires chafing against the column & some times the the wires wear into. the codes if its the problem would have been clutch slippage codes.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
post #6 of 10 (permalink) Old 01-27-2007, 05:18 PM Thread Starter
Miracles never cease, I found the invoice. They replaced the Torgue Converter Solenoid to the tune of $276.55 for the part, $20 ATF fluid, $130 for labor and $12.50 for freight totaling $439.05 It started flashing immediately again within no time at all. The OD does work, but we manually turn it off and on for going up hills etc so it won't start flashing. Again, the only way to turn the flashing off when it does start, is by turning off the engine. We did have some trouble with the shifter itself, the end of the gearshift broke off and we crazy glued it back on. Been fine ever since. If the light starts flashing it will shift hard at a slow speed. At a higher speed it doesn't. My hubby is really interested in all your input. Very helpful and thanks a lot. [img]/ubbthreads/images/graemlins/smile.gif[/img]
post #7 of 10 (permalink) Old 01-27-2007, 05:42 PM
does it go in and out of overdrive? Ihad that happen twice at about the same mileage. The first time i replaced the shifter and it fixed the problem. about 20000 miles later it came on again and wanted to stay out of eoverdrive and turned out to be the solinoid ( or how ever you spell it) inside the tranny.
squeek417 is offline
post #8 of 10 (permalink) Old 01-27-2007, 06:44 PM
NCHornet's Avatar
Sounds like your previous bill did not address your problem and I would bring this up to the shop. This is why having your own code reader is so important. That way you are not at the mercy of these crooks. Even if you bought a superchips unit, keep it for a code reader and not use the tunes. Or get a SCT2 programmer from DPTuner with awesome tunes and code reader.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #9 of 10 (permalink) Old 01-28-2007, 02:18 PM
[/ QUOTE ]Have you checked the connection to the VSS, It may be loose or corroded....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #10 of 10 (permalink) Old 02-06-2007, 04:49 PM
I don't have a solution to this but this happened to me too. The OD light would flash and it seems like the tranny wasn't in 1st gear. I thought the tranny was dying. This happened all the time. I took it in to have codes read but everyone said there were no codes. Shortly thereafter, my batteries went dead. I replaced the batteries and haven't had the OD flash since then which was mid November 2006. I don't know what the deal was but all is fine now. Still looking at upgrading the tranny.
2008 F-450 4WD Crew Cab 6.4l
Dauntless is offline
