Fluid Analysis - Diesel Forum - TheDieselStop.com
Old 05-16-2005, 07:30 PM   #1 (permalink)
Fluid Analysis
I have a SpeedCo Truck Lube a couple miles from my house. Anybody familliar with them? They have a sign out front that says they do instant oil analysis. Is this a worthwhile investment? What is the typical cost? Could I use this analysis to extend oil change intervals SAFELY?
My 3 year-36K mile warranty ran out in April. Not sure if Ford has a longer drivetrain warranty on the PSD itself. Assuming my warranty is completely up, I would like to safely "cut a few corners" for fluid changes. I had been changing my oil every 5k. I may want to extend this with an oil analysis. Is an analysis possible with the trany fluid as well?
Another post mentioned some coolant test strips to check the condition of the coolant.
What do you think? Do the over the road fleets change fluids at mileage intervals or when an analysis dictates a change?
2002 F250, 7.3L Power Stroke, Automatic, 4X4, XLT
Steelmuscle is offline
Old 05-16-2005, 07:40 PM   #2 (permalink)
Re: Fluid Analysis
Probably should have posted this in General Diesel right? Sorry, I'm learning.
Old 05-16-2005, 08:22 PM   #3 (permalink)
Re: Fluid Analysis
You're not completely out of warranty yet - the Powerstroke has a 100k mile warranty on it.
As for oil analysis, most folks in here use Blackstone oil analysis. They send you a free kit and you send them a sample. Cost is around $18. I'm not familiar with the specific place you mention, but maybe someone else will chime in.
2002 F250 Crew Cab, 2WD, Auto, 100k miles, 80hp Econo PCM, ISSPro Gauges, Ford AIS, Walker BTM.
ramblin_wreck is offline
Old 05-18-2005, 02:25 PM   #4 (permalink)
My Photos: (22)
Re: Fluid Analysis
The T-check analysis machine used by Speedco is accurate for general oil analysis purposes. The key to oil analysis is using the smae testing type over and over for trend analysis. In other words, doing one test with T-check, then the next test with Blackstone, then the next test with Butler cat will produce a disparity in the results due to each testing method not producing testing results exactly identical to each other.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
