Foil Delete Question - Diesel Forum - TheDieselStop.com
Old 09-07-2009, 12:13 AM   #1 (permalink)
Todes's Avatar
Ok, probably a stupid question or two....but never be afraid to ask.
I have a 02 7.3L and was thinking about doing the foil delete that I've seen mentioned a couple times....
Is there any down sides to doing it (I'm looking for the whistle) / will it change anything from normal operation?
I've been racking it around in my head for a couple days and can't think of anything that would happen, but figured to be safe to ask the good people of dieselstop.com
Thanks in advance
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 09-07-2009, 12:16 AM   #2 (permalink)
Browning01's Avatar
Absolutely zero operational changes good or bad will occur with the foil delete, your only gain will be a little bit louder turbo whistle.
2001 F250 7.3L White 4X4, Lariat Crew Cab, 7 1/2" Superlift, Mickey Thompson Classic lock Wheels wrapped in Dick Cepek 325/80/16 tires, 05-07 Grille and Headlights, wood dash kit, Pioneer Flip out DVD player, Cobra CB mounted under the 4x4 switch, DP-TUNER WITH STOCK, NO START, 80 ECON and 140 AGRESSIVE, DIY Intake with napa 6637 filter, IC Foil delete, new aftermarket tranny with sonnix shift kit and triple disc billet Torque converter, 4" Magnaflow Turbo back exhaust, Plantdrive wvo kit with 75 gallon external L shaped heated tank in the bed, Racor filter inline before the stock one, 146,000 miles
Browning01 is offline
Old 09-07-2009, 09:21 PM   #3 (permalink)
what is the foil delete?
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
Old 09-07-2009, 09:36 PM   #4 (permalink)
tbpower's Avatar
It is when you take the insulation off of the driver's side IC tube . It is kind of a PITA to get the insulation off.
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
Old 09-08-2009, 01:26 AM   #5 (permalink)
ahh ok, yea i dont have that on my early 99', thanks anyway
