Front end parts diagram, F250 - Diesel Forum - TheDieselStop.com
Old 11-21-2009, 08:15 PM   #1 (permalink)
Just picked up a 03 F250 7.3, 4wd, Crew cab, 190k on truck.
I have clunking noises over rough roads. Was wondering if anyone has a good parts diagram so I can describe the parts accurately.
Previous owner put on new ball joints, upper and lower. I can hear a slight clunk when I twist the long arm that comes down from the steering box.
Whats this bar called?
kapton is offline
Old 11-21-2009, 08:44 PM   #2 (permalink)
CPUNeck's Avatar
My Photos: (13)
Sway bar links, and bushings are the most likely cause of the clunk. That "bar" is a drag-link. If it's what's clunking, it's really bad. You also need to check the torque of the Panhard rod ( aka track bar)
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
SVO Conversion Updated SVO stuff
CPUNeck is offline
Old 11-21-2009, 09:59 PM   #3 (permalink)
Thanks CPUneck.
From what I've read here, I should disconnect one link to see if the sound goes away. I will go try that now.
kapton is offline
