Front wheel bearing unit install - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-28-2005, 06:42 PM Thread Starter
When replacing the front wheel bearing unit, (2000/psd/f250/4x4/r-abs/swd)are there any grease areas to pack for lubrication of the bearing and the dive axle bearing?
BURT28 is offline
post #2 of 7 (permalink) Old 12-28-2005, 06:57 PM
Re: Front wheel bearing unit install
The wheel bearing units are unitized and use sealed bearings. No lube required. If you have the ABS version of these, you could inject grease through the ABS hole.
The axle shaft bearing is a small torrigton roller bearing that could take some grease. Not sure on the Ford specs though. I just put a dab of wheel bearing grease on it when I changed my wheel bearings.
2000 F250SD SCLB Lariat 4x4
450 cubes, fully studded, modified.
4R100 built by me with Suncoast/Transgo/Sonnax/Ford parts.
325/65/18 BFG A/Ts on Ultra rims, custom 4" lift with rear shackle flip(no blocks), Rancho 9000Xs, Homemade bypass fuel system, bypass oil filter, Racor CCV filter, 3.5/4/5 custom exhaust, 8 yr old DI 4 pos chip, and some other stuff.
22 year US Navy vet (retired)
ASE Master Auto Tech
stangrcr1 is offline
post #3 of 7 (permalink) Old 12-31-2005, 02:29 PM
I am going to try to replace my bearing/hub assy this weekend, what do I need to do the job other than the new hub assy and the ratchet and socket to take apart and put together?
99 (8/98) F350 XLT CC LWB SRW 4X4 6spd ZF, Hide-a-ball Gooseneck Hitch, Line-X Bed Liner, Custom Running Boards & Camper Tiedowns, 11.5 ft Caribou by Fleetwood Camper, 24 ft Haulmark Elite 10,000 lb Car Hauler, Superchips Tuner, Toyo 305/70R16 Tires on Weld Typhoon's, Bushwacker Fender Flares
SuperdutyPSD is offline
post #4 of 7 (permalink) Old 12-31-2005, 04:03 PM
There's a large O-ring around the hub assembly. I couldn't find one anywhere except a Ford dealer.
2014 F250 CC 4X4
2001 F-250 PSD CC 4X4. Gone but not forgotten.
FordnJeep is offline
post #5 of 7 (permalink) Old 12-31-2005, 07:03 PM
What is the purpose of the O-ring
post #6 of 7 (permalink) Old 12-31-2005, 07:11 PM
There is a snap ring on the stub shaft behind the locking hub. I use a snap ring plyers to remove/replace the ring.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
post #7 of 7 (permalink) Old 01-01-2006, 11:14 AM
I know I had my front right replace last week at the dealer and they also informed me that the shaft that goes into the differential was scratched up. End result I ended up shelling out $2100 for repairs. They replace wheel assembly, shaft and both 4x4 hubs...
soooo good luck if you can do it yourself.
TxBlueroan is offline
