Re: FTVB compatibility with DiabloSport tuner?
It should be 80 lb/in for the VB bolt torques. When you do the install be prepared because its going to be very messy. On your Predator you should be able to set it to use no trans tuning. Simply turn off the trans tune and you're fine.
Early 99 F250 PSD XLT, Ext cab Short box 4x4
Engine mods: CCV reroute, DIY intake using Green filter, 4" SS MBRP downpipe, 4" straight pipe exhaust, DP Tuner stock/40/80/120 chip, ATS BB turbo on the way, FASS fuel system
Drivetrain mods: FTVB, Suncoast SD43 TC waiting to go in.
Exterior mods: Putco billet grill, Owens fiberglass running boards, 265/75/16 MTRs
