fuel bowl heater - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 06-01-2013, 03:15 PM Thread Starter
tvengineer's Avatar
fuel bowl heater
Pulled my fuel bowl out today to clean up some leaks. My heater element was separated from the plate it's supposed to be attached to. I looked up a new one one Guzzles site and the one like I have states it's for a 94-97 7.3. My truck is a 2000 f250. There is another element listed but does not give a year for it. Which should I buy?
Also, what is the sensor located in front of the hpop where the bolts go to hold the fuel bowl down? I broke that connector accidentally.
2000 F250 7.3 mostly stock
Gauges- Trans, Boost, EGT, Fuel Pressure
tvengineer is offline
post #2 of 6 (permalink) Old 06-01-2013, 03:50 PM
RT
RT's Avatar
This is the fuel heater you need - 1999 - 2003 Ford Fuel Bowl Heater Element
The sensor in front of the HPOP is the Exhaust Back Pressure Sensor. Exhaust Back Pressure Sensor 1997-2003 7.3L
RT is offline
post #3 of 6 (permalink) Old 06-01-2013, 04:26 PM Thread Starter
tvengineer's Avatar
thanks, that's not the one in my fuel bowl but it will be. A new sensor will be coming also.
post #4 of 6 (permalink) Old 06-01-2013, 04:28 PM
RT
RT's Avatar
Right - yours was a wire tack welded in a few places - they had a habit of breaking loose and shorting out. The one I linked to is the "updated" version.
RT is offline
post #5 of 6 (permalink) Old 06-01-2013, 04:59 PM
klhansen's Avatar
My Photos: (180)
Here's some more info about the old style fuel heater.
Shorted fuel heater - fixed
), AIS,
regulated return,
klhansen is offline
post #6 of 6 (permalink) Old 06-01-2013, 05:18 PM Thread Starter
tvengineer's Avatar
interesting stuff, I must have a hybrid engine/truck. I have the old style heater and while I have things apart I did the fuel rail plug hole drilling like suggested by powerstrokehelp. He made mention in that video about the slight difference in plug bolts. I seem to have the pre 2000 bolt not yet the later model one. Makes me wonder if thie engine has ever been swapped. I do not have the older turbo wheel though. My truck also has the v8 emblem on the front fenders to, seemingly indicating a pre 2000?
