Fuel bowl heater element - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-13-2011, 02:46 PM Thread Starter
scrapin's Avatar
I started my 7.3 went to back it out and it stalled. Tried starting again, i cant hear the fuel pump turn on. The #30 fuse is blown, and the truck will not start. I put another fuse in it, truck started then stalled, fuse is blown again. Is the heater element shorting the fuse or is it the fuel pump? Can i disconnect the harness for the element and it will be ok to drive, meaning will it stall on me again with this disconnected?
And if it is the element how do i change it out?
thanks
2008 F250 XLT 6.4 40k miles 4x4, , 3/04' 6.0 F350XL PSD 4x4 dually dump, moog ball joints, 9' min. mt.2 fisher plow----- 2001 F250 5.4 liter gasser 4x4
scrapin is offline
post #2 of 5 (permalink) Old 03-13-2011, 03:11 PM
RT
RT's Avatar
#30 blowing is definitely the heater element. It will be perfectly fine to unplug it and drive it that way. You might want to change it out before next winter - use the updated version available here:
Replacement O-rings for Ford Diesel Engines
Be aware that unplugging the heater also disables your water in fuel, so make sure and drain your bowl at each oil change. Tape the loose connector just to prevent accidental bouncing around and possible shorting out.
RT is online now
post #3 of 5 (permalink) Old 03-14-2011, 08:33 AM
Im with RT, just unplug it for the time being and follow up on what RT said to do to fix it
1999 Ford F-250 7.3 Powerstroke Diesel
4X4 automatic...and stock everything..
311,000miles and climbing
mims73 is offline
post #4 of 5 (permalink) Old 03-14-2011, 08:49 AM
Enf0rc3r570's Avatar
There is also a thread with good pics and info for fixing the element if it's broken and that's the problem. Just do a search.
2001 F250 Crew Cab Lariat short bed FX4 7.3L PSD 119k miles, automatic, 4x4, muffler delete pipe, DIY Donaldson intake,
Boost fooler, Turbomaster wastegate actuator, Auto Meter GS series pyro & boost gauges, Rough Country leveling kit, Skyjacker dual steering dampener, Mile Marker manual hubs Falken Wildpeake AT 315/75R16, DP Tuner F5, 80 Econ, 120 Race, 140 Aggressive
Enf0rc3r570 is offline
post #5 of 5 (permalink) Old 03-14-2011, 09:02 PM
klhansen's Avatar
My Photos: (180)
That would probably be this one: http://www.thedieselstop.com/forums/...-fixed-239318/
), AIS,
regulated return,
klhansen is offline
