Fuel Filter Cap Removal; tool needed? Help? - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 07-03-2005, 10:41 AM Thread Starter
Happy independance weekend everyone! I hope those of you that are here anr looking forward to some fun later today or tomorrow!
Please help! Need to change fuel filter in my '03 7.3. Manual suppliment says simply unscrew the cap counter clockwise. Thanks to some previous threads, I found and opened the fule drain valve/lever so the pressure has now been relieved. Funny that this part was not in said manual! [img]/ubbthreads/images/graemlins/wink.gif[/img] The cap is on very tight. I have tried an oil filter wrench with no results.
Is there a tool that I need or am I missing something else the manual suppliment left out? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2003 F250 7.3 PSD Lariat, CC FX4 off-road, born on 07/02. Tymar air intake, 6pos chip with stock, hi-idle, 40,80,120, and no-start settings, Silverline TB 4" exhaust. BEAN'S DIESEL ROCKS! Purchased used with 51k miles. Daily driver and gets me to the track.
rjarvis is offline
post #2 of 21 (permalink) Old 07-03-2005, 10:46 AM
My Photos: (22)
Re: Fuel Filter Cap Removal; tool needed? Help?
Click this link: Tool from Napa
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #3 of 21 (permalink) Old 07-03-2005, 10:57 AM Thread Starter
Thanks Hammer! Just what I thought. Wish i would have thought of this first. Hope you enjoy your holiday!
Rich
rjarvis is offline
post #4 of 21 (permalink) Old 07-03-2005, 11:05 AM
JimmyDee's Avatar
My Photos: (24)
I bought one from http://www.dieselpage.com/main.shtml but don't see it listed in their on-line catalog. I think I had to call them. It was around $6.
You can also make one out of PVC pipe. Just cut notches in the bottom of about a 6" piece of pipe that match up with the top of the filter and then drill a hole in the side that will receive a large screw driver. Several here have made and used a homemade one like this.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod;
, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in
AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
post #5 of 21 (permalink) Old 07-03-2005, 11:14 AM
I built mine out of a 1/4" X 8" flat bar. I measured the slots on the cap and drilled 1/4" holes in the flat bar then put a 1/4" X 1-1/2" bolt in both holes. Makes a great wrench. I keep mine behind my truck seat.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
post #6 of 21 (permalink) Old 07-03-2005, 11:54 AM
I just use my large channel lock pliers, and a long screwdriver.
Put the open ends of the channel locks into the holes, insert the screwdriver thru the pliers and twist. It works for me.
2001 PSD Super Duty F350 XLT 2WD SRW Shorty 4SPD. BD Performance Trans.& Conv. K&N Air Filter,Line-X, Mag Hytec Diff. Cover, BD-Exh.Brake, Elec.trans.cooler,3-gauges/A pillar. 2003 Alpenlite 32ft Augusta 5er.
Firestone Air Bags. Michelin XPS LT 235/85R 16/E
1 Choc. Lab.
Dozer Don is offline
post #7 of 21 (permalink) Old 07-03-2005, 05:12 PM
Banned
I just use two crossed screwdrivers.... put the tips in the right places, cross them the right direction.... the lid is off....
GrampyJim is offline
post #8 of 21 (permalink) Old 07-03-2005, 06:44 PM
Ran440's Avatar
FYI:
The PSD oil filter and the fuel filter cap are the same size. Meaning you can use your oil filter wrench to remove the fuel filter cap. That is what I use.
Randy
1999 ( Build date 10/98 ) 1-Owner F-250 XLT PSD, XLE8 ( started out as XLE4 ), Auto Trans w/sonnax valve tricumulator springs, 4x4, manual hubs, manual shift transfer, 3.73 gears, Tymar intake, open air CCV, A-pillar 3 gauge W/Auto Meter pyro, boost, trans and axle temp in Mag-Hytec covers, Banks 4" monster exhaust, DI 4 Position Flip Chip stock-75-100-110, early 99 turbo conversion W/ ATS BB Turbo, gutted EBPV, Smitybuilt bumper guard, Lund bug deflector, Lund SS cold air grill guard, Wet Okole seat covers w/Powerstroke logo, custom made floor mats ( way better than any store bought mats )
Buy American, Keep Your Job.
Ran440 is offline
post #9 of 21 (permalink) Old 07-03-2005, 07:09 PM
My Photos: (22)
FYI:
Randy
Did you read his whole post? He said, "I have tried an oil filter wrench with no results."
Hammer
I still have the:
<font color="red">
</font>
post #10 of 21 (permalink) Old 07-03-2005, 07:20 PM
I have a "strap wrench" that I bought at Advance Auto Parts for about $3.00 that works really well, It is a nylon strap on the end of a square bar that a 3/8" sockect ratchtet fits in the other end. As I turn the ratchet, it tightens the strap around the cap until it is tight, and it then has the leverage to spin it off.
99.5 F250 PSD Supercab, 2WD, 6 Speed, 3.73 LS with PML Cover, 4" Exhaust; AMSOIL Front to Back (Dual Remote Bypass Filter, Air Filter, engine oil, ATF in tranny and power steering, and differential gear lube), U.S. Gear D-Celerator Exhaust Brake and Cyclone Power Fan, PullRite Super 5th Hitch, TransferFlow 96 gal Fuel Tank, Ultra-Fab Trail-Eze II Wind Deflector, J-MAC Vented Tailgatge, C-Betr Mirrors, Cup Smoothie, SuperChips
lhansford is offline
post #11 of 21 (permalink) Old 07-03-2005, 11:41 PM
Banned
HUH???
post #12 of 21 (permalink) Old 07-04-2005, 08:15 AM
JimTJr's Avatar
My Photos: (20)
I dont think I could get an oil filter wrench around it and still have room to try and turn it either..[img]/ubbthreads/images/graemlins/shrug.gif[/img]..seems I remember trying the first time too.
I used a LARGE pair of channel lock pliers,,I mean the handles were about 18" long...they worked fine. DONT put a ton of arm on it when you reinstall the cap. Then I got that nice "Billit" fuel filter cap from BTS when I bought my tranny... [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #13 of 21 (permalink) Old 07-04-2005, 10:44 AM
jwehrer's Avatar
Regular pair of pliers. Spread the handles apart and place them vertically so that the handles fit down in the grooves towards the outside. Use a crescent wrench around the top of the the pliers where they are fastened together and turn counterclockwise and it's off.
2001 F350 4x4 XLT Lariat Crew Cab, 7.3 Liter PSD 6-speed Manual, Warn Hubs, Manual 4WD, Long Box, Century Canopy,
jwehrer is offline
post #14 of 21 (permalink) Old 07-04-2005, 11:23 AM
Sounds too simple, doesn't it? [img]/ubbthreads/images/graemlins/wink.gif[/img]
post #15 of 21 (permalink) Old 07-04-2005, 01:29 PM
My Photos: (11)
Larry M is offline
