fuel filter frozen??? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-11-2006, 09:19 PM Thread Starter
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Hello everyone,
after siting outside overnight at about - 15 Celsius, it started OK, let it runing while unpluging the heater cord, and I have seen tons of fuel leaking.Stoped the engine,and found out after hours of checking that was the fuel filter,but not sure where exactly,because was no way to keep it running and stay closer than few yards.Changed the filter,everything seems OK,looking forward to the winter....Few facts: filter changed about 3000 km ago,no sign of water in fuel,filter top plastic thing looks a bit funny,not sure how it is supposed to look.Any suggestions why this happened? thank you
1999 E350 Superduty 7.3 Powerstroke,automatic, 144000 km,everything stock.
whitewizards is offline
post #2 of 3 (permalink) Old 12-11-2006, 09:29 PM
Re: fuel filter frozen???
replace the o-rings on the water drain valve located on the back of the fuel bowl. These have been giving everyone problems lately. While you are at it change all the seals on the ends of the 4 fuel lines leading into the fuel bowl. If you purchase the seal kit from the dealer you will get all the seals in one pack for around $24 US.
Early 1999 F350 CC/LB 4x4, 7.3L, 3.73LS
*6" Lift
*315/75/16 BFG AT,
*16x10 Outlaw II's(not my favorite rim),
*Warn Hubs
*203 degree T-Stat
*lotsa lights
*Tymar HX hose
*Dual 5 inch stacks
*Tymar Intake
*Isspro guages and color matched triple pod
*Fresh beefed up 4r100 from Greene @ Quality Trans. in Anchorage Alaska
*TS 6 pos chip-no start, high idle, 50, 75, Fuel 7, 140 xtreme....
*Tymar coolant filter kit
*6.uh oh Intercooler
*Firestone RideRite 5,000lbs bags
Next on the list: Stage 1 or 2 injectors, BIG OIL
dslfumes is offline
post #3 of 3 (permalink) Old 12-12-2006, 08:31 PM Thread Starter
Thanks Dslfumes, will do so.
Gear in this thread - Powered by O'Reilly Auto Parts
