This is my first thread posting on this site. I've got a 2000 7.3 and its leaking diesel fuel. I located the leak coming from the fuel drain valve. Guessing its one of two o-rings needing replaced? So I went to Ford today and got the o-ring set. Has anyone encountered this leak? Also will the diesel fuel mess anything up that it has leaked on and should I spray soapy water down in the valley to remove all fuel and residue? Could this leak cause a decrease in power? Thanks to anyone who can help.
I'm guessing we all have experienced this. It is probably the most common leak on a PSD. No decrease in power - just leaking diesel. It won't hurt anything, but you should keep the valley reasonably clean so you can identify future leaks. There are actually three o-rings you should replace - one inside the valve and two at the mating surface. Check out this site for a .pdf instruction (where you should have bought the o-rings
dray8165 thanks a lot. The Ford dealership charges $67.10 for the fuel filter O-ring set! I'll be returning it and ordering the set from that website.
$67 should be for the valve itself which is what leaks - not the o-rings. (at least I have never seen the o-rings FOR THE VALVE cause a leak) Incidentally the valves were on backorder from the supplier not long ago and I had to wait a week for the one I ordered to come in. I think we ended up getting it from another dealer.
__________________ . Ford Master Diesel Technician Diesel Technician Society Diesel Mentor Directory
Yeah but it's ford! If they charged $28 for a fuse it wouldn't surprise me at all. I would buy a new engine before i'd buy a set of injectors at the dealer. They got me way back on a gpr, nobody had one and mine decenegrated and they charged me $96 for a $25 part.
1995 cc dually 2wd. 175,000,edge evolution, 4" imco exhaust and tymar intake. zf5 with redline synthetic and mobil1 synthetic everywhere else. pre and post turbo pyros and yes they both read the same.
My o-rings were bad on my truck and once i replaced them the problem was solved! You have to get the o-rings that are made from Viton because they will withstand the punishment of the fuel.The size of them is #202.What happens is,after time they become hard and don't seal anymore.Its a easy fix,you will need a 1/4 ratchet and a #20 torx socket.Disconnect the drain hose from the yellow valve then the 4ea screws that hold that valve on the back of the fuel bowl.Use a pick to get the 2ea o-rings out then replace them with the new ones.Make sure you put diesel on the o-rings so they won't be dry when cycling the valve for the first time.FYI there is a 3rd o-ring in the valve and i believe its on the valve stem.I have done 3 different trucks this way and had sucess everytime........Btw a small set of hands is a plus.I got the o-rings on line in a bag of 25 and it all came to a total of 5 cents per o-ring...good luck!
1999 Ford F-250 7.3 Powerstroke Diesel
4X4 automatic...and stock everything..
259,000 miles and climbing
not just the drain. Heater O Ring likely starting to deteroiate, also. Kits on the web. Look at Vitrol O Rings
Scott
MMC/ss Retired - Still bound by my oath to Protect and Defend the Constitution from all enemies foriegn and DOMESTIC
NRA Life Member
03 F-250, Auto, CC/SB, 3.73LS, XLT FX4, Tiejtan Front Replacement, Ruenel Rear Bumper, Rancho Leveling Kit, Airbags, Dynatrac Free Spin / Warn Hubs, Dynatrac Front Dif cover, Tire Gate, Mag-Hytec Rear Diff, 46 gallon tank, Cryo Treated Rooters and Steel Braided Brake Lines, 203 T Stat and Billet housing, Marinco, Auto Meter: EGT, Boost and Tranny, 4" SS Turbo Back, pre pump and regulated return; HP X, AIS, AIH Delete, Banks IC, DP Tuner - 60 HP Daily / 80 HP Tow (both no codes) and the best for last - BTS with 6.0 cooler!
I know ford has hit their head when it comes to some of their $$, but I can at least give you the best deal fom a dealer
Also, I believe any oring kits the fuel filter housing include way more than you need for just the drain valve, and hense the high $$
We are Tousley Ford parts depot selling all OEM Ford parts 10% over dealer cost. We sell heavy truck parts as well!
Please PM me for any price requests
Call us at 1-800-328-9552 OR check out our website www.tousleyfordparts.com Be sure to mention this website for the good discount.
Should I just replace all of the filter o-rings? I mean might as well I found the kit for $16 and if I'll be working on the fuel filter already might as well replace all o-rings just in case anymore might start to leak in the future.
While I agree with ScottWilliams that they are all likely drying up, the fuel drain valve is the only one that "moves" - it usually doesn't start leaking until some well meaning soul decides to drain the fuel filter chamber for the first time in years. You can also change it without removing the filter / housing and the o-rings are so cheap that if it were ME, I would only change the leaking ones now and just keep an eye on the others until they gave me a problem. But, hey - if you've got a day to kill, and don't mind the frustration - rebuild the whole thing...
That's what I'll do. Just changing the drain valve o-rings will hopefully do the trick, there is residue on the wire and connector to the heater/water separator but that may be sprayed on while under pressure. When the truck is on idling I see fuel dripping from underneath the drain valve and not from under the heater/water separator.
The truck was driven 1200 mile since '06 and I just bought it in the end of '09. It had 71800 miles when I bought it. It wasn't driven many miles for the past year if any. All I know is I'm tired of smelling diesel fuel from in the cab. As soon as the o-ring set arrives its gettin done.
With this fuel leak am I likely to get better mileage when fixed? I know it drips frequently when idling but not sure how much I loose when driving. Truck is reg cab with 4.10 gears and now I average 14MPG. That's combined city/hwy. Its got a new air filter. I drive it slow. Will the leak repair dramatically increase mileage?? has it for anyone here who experienced the same problem. Thanks.
No. Unless it is a continuous stream u wont see any improvement. Easy on the pedal, feather at 1800-2000 rpm, dont exceed the speed limit ever, air the tires properly, change filters, oil regularly and hope. Thats all we can do. With 4.10's in town 14-15 will be good.
I shift at 1700-2000 every time, its embarrassing with all of the other cars zippin around me because it takes off like a tortoise and I finally catch up around 4Th gear going in OD. I think a size up in tires will help with hwy fuel mileage. I can tell you that I let it idle for about 5-10 minutes one night and looked underneath it to see if it leaked and there was a puddle 24 inches wide of diesel fuel.
