Fuel Gauge Stays Pegged on Full - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 10-11-2005, 10:56 PM Thread Starter
Kanman's Avatar
I don't think I am lucky enough to have the magical fuel fairy coming to visit me with a fresh tank of fuel every night so where should I start with my little problem?
Key off needle drops to empty position, Key on needles pegs back to full and stays there. By my estimation (miles traveled on this tank) I should be somewhere near the half full mark by now. Where should I go with this?
Kanman is offline
post #2 of 19 (permalink) Old 10-11-2005, 11:39 PM
Re: Fuel Gauge Stays Pegged on Full
My truck had this problem last week. I just filled the tank and tapped on the tank with a rubber mallet, that fixed the problem for me. If that does not fix the gauge it could be a electrical problem or the float could be stuck in the tank.
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #3 of 19 (permalink) Old 10-11-2005, 11:39 PM
How many miles has it been?
With th e large tank if I fill all the way to the neck it will go almost exactly 134 miles each time before the guage moves a little.
From absolutely full to just below 3/4 is about 15 gal. from there to about a 1/2 tank on the guage is another 5 gal give or take a little..
reyjay is offline
post #4 of 19 (permalink) Old 10-12-2005, 09:17 AM
Kanman,
I posted the same problem earlier this week. If you figure something out pm me. thanks,
Joe46
PS. 1O6 said to try a real bumpy road-did that-no change
01F350 CC 4WD 6SPD Arrow Canopy, 305/70/16's on 16"X8"wheels, HX mod, IAH plug, AFE Stage I w/pro guard 7 filter and overcoat. Evo tuner, WW, 4"exhaust,zoodad, Amsoil, Isspro gauges, GOS headlight harness,coolant filter
Endowment Member NRA
01crewcabtg is offline
post #5 of 19 (permalink) Old 10-12-2005, 10:46 AM
I've tried the bumping and the tapping and the driving and the jogging and nothing works for me but dropping the tank. Did mine again last week and it always is jammed up at the top pretty tightly. The float arm seems to be slightly longer than the distance from the pivot to the top mount, so if it gets slammed up there, it move over center and looks in place. Ugh. I don't see it coming loose by itself. I think next time I'll probably just bend the float arm a little bit and live with whatever gauge inaccuracies I get from it.
If you guesstimate it to when there's less than 10 gals left, it's not a bad job to drop the tank enough to get the sending unit out of the top. Took me about 45 mins last time.
Good luck.
2000 F-250 4x4 SC LWB 6 spd, manual hubs, Dynomax muffler, Westach pyro/boost gauge, Tymar intake, Tuff Country leveling kit, RS9000s, Warn fender flares, Reaper Racing Pre-runner Bumper, "Gold" Coolant, 86k and going strong...
Highway Tires - Dunlop Radial Rover AT 255/85R16 on stock XLTs.
Wheelin' Tires - 315/75R16 BFG Mud KMs on 16x8 Weld Evo Renegades.
BigE is offline
post #6 of 19 (permalink) Old 10-12-2005, 01:31 PM
I was wondering if this was an issue with the tanks when guys do the Harpoon Mod. Seems to me that if you fill it all the way up plus some, you risk sticking the float. I'm planning on doing the Harpoon Mod myself, is there anyway to put an upper stop on the float to prevent sticking? Seems that a bolt clamped on (with the appropriate lock washer, etc. to prevent it from coming off) or other type stop would be feasible without having to bend the float arm. Since I haven't seen the pieces parts to this thing yet, I'm curious of the opinion of the guys who have.
F-250 Super Duty 4X4 7.3L turbo, Crew cab, long bed. Banks Power Pack and Power Elbow. A/C shutoff valve. In-tank and fuel return mods and harpooned. 203F thermostat and coolant filter, and 6.0 tranny coller. Collecting dust waiting to be installed: CCV Mod.
Navy LDO LT with 23 1/2 years
jrshippy is offline
post #7 of 19 (permalink) Old 10-12-2005, 04:14 PM Thread Starter
Kanman's Avatar
Kanman,
Joe46
Joe, I was reading that thread last night. I was hoping one of you guys figured out an easy solution by now; guess not [img]/ubbthreads/images/graemlins/crazy.gif[/img] I would rather take a butt whoopin than have to pull the tank. The thought of diesel fuel raining down on me does not excite me in the least bit lol.
Mine quit working last weekend as I was being a goon at the track, racing again and again. I wonder if the fuel slosh bent the float guide somehow and its wedged in there? Not sure how everything lays in there, guess ill have to go hunt down a photo.
Kanman is offline
post #8 of 19 (permalink) Old 10-12-2005, 04:42 PM
This has hapopened to me 3 different times. In every instance, once the tank was refilled to the brim, it dislodged it. I have 188K on my truck, so it does not happen often. I always fill up my truck to the brim. My bet is if you refill your tank the issue may resolve itself.
Good Luck
99.5 F250SD 6 speed Ext Cab Long Bed/Custom Grille/ Hood/ DPPI 4"down w/dual tips/AFE II/ Evans Coolant w filter& 203 Deg. thermostat/ARE bed Cap/Centerline Tracker 9 x 16 w Michelin 265/70/16 /Brite Box/ Gear Vendor OD/Line X bed Liner/ATS Turbo Housing/Velvet ride Shackles/X Monitor EGT & Boost/ TS 4 position chip/Air Dog/ DI Fuel Tank sump/DI High Perf. fuel delivery system/DI External fuel regulator bypass kit/ Centramatic wheel balancers/05 Headlights
MrBee is offline
post #9 of 19 (permalink) Old 10-12-2005, 08:06 PM
I haven't done the harpoon mode on my tank. The last time I went wheeling, I only filled the tank up about 2/3 of the way and it still happened. I think how hard you bounce it around effects how easy it is to become unstuck. None of the other tricks have ever worked for me, and once I got in there and unhooked it by hand, I can see why. In my case, it's been pretty well pinned in there every time.
You may be able to figure out something to stop it, but my guess is that a slight bend in the arm would be the quickest and most likely to fix and not damage anything else approach. I would say the throw on the float is probably around 12", and the bend probably only needs to be enough to reduce this down to about 11", so I doubt it would effect the gauge reading that much.
I'm sure there's lots of ways to skin this one though...
BigE is offline
post #10 of 19 (permalink) Old 10-12-2005, 09:36 PM
Mine's been that way since late spring.... I've been dreading dropping the tank for just the gauge. When I did all my fuel mods I had the bed off. Anyway I just keep good track of the miles that I travel on a tank. I did this before just to keep a rough track of fuel economy, so it isn't a big enough deal for me to want to drop the tank yet.
Jason
2000 F250 Pulling Truck 400cc of fuel and a built motor to handle it
2006 Dmax cause I needed a daily driver with cheap power
1968 Chevy C-30 4x4 dually with a Cummins conversion
hotrodtractor is offline
post #11 of 19 (permalink) Old 10-12-2005, 09:42 PM
I have a different problem. I can fill the tank up, drive almost exactly 23 miles, and I have 3/4 of a tank left. I refuse to believe I have burned that much fuel. I usually get 305 to 325 miles to a tank. I bought this '01 with 40,000 miles on it. Any suggestions?
Thanks,
Chad
***STOLEN*** 2001 F250 Black Lariat 4x4 Crew Cab Short Bed Auto License #5YF F59
SCMT 1705
Daily Commuter
natvtxn27 is offline
post #12 of 19 (permalink) Old 10-13-2005, 07:49 AM
Trade it... WOW, 325 per tank (I am assuming approx. 28 gallon tank)... That is 11.5 mpg. Are you towing or unloaded? If towing it isn't that bad. If it is all unloaded, there is a problem somewhere. At something that poor, I would be looking for a leak (tank, fuel filter drain bowl - possibly the 10 cent gaskets/o-rings behind the fuel filter drain valave are leaking). Fuel has to be going onto the gound somehow to get that poor mileage... Just my SWAG!
2003 Red F-250 XLT Sport Crew Cab, Short Box, 4x4, ESOF, Auto, 7.3L PSD, 3.73 LS, Husky Job Box, Michelin LTX's, Eclipse Head Unit, Memphis Audio Sound, and a Dale Jr Chrome # 8 Hitch Cover Plate!!!
jonDIESEL is offline
post #13 of 19 (permalink) Old 10-13-2005, 09:42 AM
Every fill up usually requires about 20-21 gallons if I wait until the low fuel light comes on. I am wondering if there is a problem with the float, and i really have 7-8 gal more when the gauge/light says it is empty? Like I said, I haven't had this truck long and just assumed it had a smaller tank. Is that possible?
I don't tow with the truck but I do carry 800-1000 lbs. of stone int the bed all the time.
SCMT 1705
Daily Commuter
post #14 of 19 (permalink) Old 10-13-2005, 10:08 AM
I believe ALL CC SB's have the smaller tank (28-29 gallon)...
post #15 of 19 (permalink) Old 10-13-2005, 10:36 AM
Well according to the Owner's guide I've got a 29 gallon tank.. The 23 gallon is on the cab & chassis model w/ the neck on the right side.
I guess I will have to drop the tank to check it out. Any other suggestions? Thanks for the insight
SCMT 1705
Daily Commuter
