Fuel Gauge Stuck on Full - Diesel Forum - TheDieselStop.com
Old 11-08-2009, 04:44 PM   #1 (permalink)
My fuel gauge is stuck on full. What can i do to fix this and what would be causing it? any help would be greatly appreciated.
espx21 is offline
Old 11-08-2009, 04:54 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
If the wire to the sending unit in the tank is broken or disconnected, the gauge will read full. So check the wiring.
It's also possible that the float is stuck up against the top of the tank. You may be able to fix that by hammering on the tank with a rubber mallet. The fuel level should be below full when you try that. It may unstick the float.
Welcome to TheDieselStop
Hard or no-start? Check Here
klhansen is offline
