Try calling Swamps Diesel Performance they have the needed tools to do the job for rent. You need to pull the injector and then use the tools to remove the cup. Do you know which one is leaking? They also sell the cups. I think if it were me I would change them all to keep from contaminating the coolant again. You will also need all new injector o-rings so order them too.
Ken
Powerstroke Acronyms
TSB Information
