Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-05-2008, 08:04 PM   #1 (permalink)
Fuel Leak!! Need Help
leaking fuel on top of motor,replaced the dump valve and filter , now it appears like it might be spraying from a line under the turbo. are there any connections through there that might be bad or do i need to replace the whole line? Its dark now so its hard to tell under shop lights will blow off in the a.m. but looking for suggestions. Only been a month since i had motor out of truck, could have caused damage to it then, maybe? I dont know. Diesel is to high to be dumping on the ground tho i know this much for sure.
99 f-250 7.3 edge programmer, afe intake , mbrp exhaust, custom red paint w/ black and blue air brush graphics, 315 BFG At on AR wheels, cervinis fiber.ram air hood,custom grill,carbon fiber tail lights 270,000 on original motor BTS auto tranny at 260,000 diprocal gauges
tile man is offline
Old 05-05-2008, 08:25 PM   #2 (permalink)
Did you replace the rubber supply lines from pump to filter bowl mine has 4 different hoses on it.
Copyman is offline
Old 05-05-2008, 08:33 PM   #3 (permalink)
no not yet but it almost seems that fuel may be spraying way up under the turbo away from the bowl. not sure, could this be right?
tile man is offline
Old 05-08-2008, 03:56 PM   #4 (permalink)
Had the same problem last week. The tubing that feeds fuel to the passenger side head was rubbed through by a clamp. I had to remove the turbo intake manifold and the glow plug relays to get to it. Have a new o-ring kit on hand, don't re-use the old ones or you'll be doing the job twice.
By the way, get it fixed fast...a side effect of a fuel leak in this area is that your starter gets soaked with diesel. This can cause a complete failure or short out windings which makes the starter spin slower, which causes hard starts and seriously overdraws the batteries.
Blue Dog is offline
Old 05-08-2008, 04:03 PM   #5 (permalink)
klhansen's Avatar
My Photos: (82)
His Superduty doesn't have a pump in the valley like your truck (94-97?).
The metal line that Blue Dog replaced has rubber ferrule compression fittings on each end. I'd check there first (one at the fuel bowl, and one at the rear of the passenger side head). If those are tight, then the line clamp (plastic coated) may have rubbed thru the steel line.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 05-08-2008, 07:05 PM   #6 (permalink)
thanks , clamp rubbed hole in line, had a time getting new line on, the bends were not identical to old line so it didnt fit. Ford claimed itwas correct line, after several hours of tweeking,got it to work. did u re-use the clamp or do away with it.? had a few tell me to ditch it .
tile man is offline
Old 05-09-2008, 09:03 AM   #7 (permalink)
I used some stainless tubing that I had on hand to replace the factory tubing. Since the tube wall was thicker I didn't reuse the clamp.
Blue Dog is offline
