| Register | Home | Forum | Active Topics | Gallery | Search | Today's Posts | Mark Forums Read |
| 7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Fuel Leak!! Need Help
leaking fuel on top of motor,replaced the dump valve and filter , now it appears like it might be spraying from a line under the turbo. are there any connections through there that might be bad or do i need to replace the whole line? Its dark now so its hard to tell under shop lights will blow off in the a.m. but looking for suggestions. Only been a month since i had motor out of truck, could have caused damage to it then, maybe? I dont know. Diesel is to high to be dumping on the ground tho i know this much for sure.
99 f-250 7.3 edge programmer, afe intake , mbrp exhaust, custom red paint w/ black and blue air brush graphics, 315 BFG At on AR wheels, cervinis fiber.ram air hood,custom grill,carbon fiber tail lights 270,000 on original motor BTS auto tranny at 260,000 diprocal gauges |
| Sponsored Links | |
Advertisement |
#3 (permalink) |
no not yet but it almost seems that fuel may be spraying way up under the turbo away from the bowl. not sure, could this be right?
#4 (permalink) |
Had the same problem last week. The tubing that feeds fuel to the passenger side head was rubbed through by a clamp. I had to remove the turbo intake manifold and the glow plug relays to get to it. Have a new o-ring kit on hand, don't re-use the old ones or you'll be doing the job twice.
By the way, get it fixed fast...a side effect of a fuel leak in this area is that your starter gets soaked with diesel. This can cause a complete failure or short out windings which makes the starter spin slower, which causes hard starts and seriously overdraws the batteries. Last edited by Blue Dog : 05-08-2008 at 04:04 PM. |
#5 (permalink) | |
The metal line that Blue Dog replaced has rubber ferrule compression fittings on each end. I'd check there first (one at the fuel bowl, and one at the rear of the passenger side head). If those are tight, then the line clamp (plastic coated) may have rubbed thru the steel line.
First truck -- 1929 Model A Ford pickup, restored from ground up. Wish I still had it! 99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.Hard or no-start? Check here |
#6 (permalink) |
thanks , clamp rubbed hole in line, had a time getting new line on, the bends were not identical to old line so it didnt fit. Ford claimed itwas correct line, after several hours of tweeking,got it to work. did u re-use the clamp or do away with it.? had a few tell me to ditch it .
