Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-02-2008, 11:15 PM   #1 (permalink)
Fuel tank overflow
'02' F250 super cab SWB I have tried to fill the tank as full as I could get it on normal fillups. I now have an extra tank in bed that has a gravity feed to main tank. I have always kept the pit**** closed (until needed) until now. Friends who have Chevys always left theirs open. On last trip I opened it while stopping to eat. Came out and there was a puddle of diesel on the ground. It looked to overflow at the connection of electrical and feed for motor on top of tank.(Large round screw cap) Is this not like the Chevys? Does it have a breather on top of the tank? I need help.
mjb59 is offline
Old 07-04-2008, 03:42 AM   #2 (permalink)
klhansen's Avatar
My Photos: (85)
Might be the fuel line quick connects on the top of the tank. They're o-ring sealed and are notorious for leaking under vacuum (pump suction). Maybe yours has gotten bad enough that it's leaking under the pressure from your aux tank. If that's the case, the fix is to cut off the QD fittings and replace with hose clamps.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 07-04-2008, 12:03 PM   #3 (permalink)
There's also some other QD for air flow under there. Those might have also come undone.
2002 F-250 black super cab 7.3 L PSD auto trans. 4X4 Lariat with a little lift and mud tires. In-bed aux tank wired to selector switch and filled with fresh clean vegetable oil. Booyah.
jordanmills is offline
Old 07-05-2008, 02:08 AM   #4 (permalink)
I believe there are two breathers on top of the tank; one on each end of the tank. About every other tank I have dropped has a broken vent line on the rear breather. If your meats are small enough you can probably fish around on top of the tank to verify.
Probably wont help your situation, but Northern Tool sells a kit that controls overfilling. Diesel Install Kit for Auxiliary Diesel Fuel Tank — Fits Ford and Dodge Trucks, Model# 011025 | Auxiliary Fuel Tanks | Northern Tool + Equipment I purchased one, but never installed it; so I cant really say how well it works either way.
Just eating rainbows and pooping butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 07-06-2008, 12:10 AM   #5 (permalink)
I have that kit installed. I would not call it an overflow preventer as the ball in the valver does not look like it will "float" up and stop the gravity feed. I would liken it to a roll over valve to stop the flow should you flip the rig.
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
Old 08-18-2008, 03:24 PM   #6 (permalink)
Overflowing tank
I had a tank that was a gravity flow for about a year. It was nothing but problems. The factory tank was alway leaking from the top of the tank after installing the transfer tank. Once my wife opened the filler cap on the factory tank to fill it up. The diesel clean up cost us $3500. The last straw was when a trooper saw the RDS tank and the hose connected to the bottom of the tank. They towed my rig to impound. They made me remove the tank from the truck and the premises. Then I got my truck back.
I asked them why. I thought the regulations said no gravity flow to the carb. I was flowing to the tank. They said that's true. They said the DOT regulations state that the fuel pick up point has to be above the highest fuel level for a fuel tank. It was another expensive lesson to learn.
I decided the $600 tank that I saved so much money on was costing me an extra $8,000. I sold it on EBay for $100. I have a system from American Tank now, www.auxtank.com. It cost me $1500, but I have had it on 4 trucks now and have almost 1,000,000 miles on the system. All we did was replace the fuel hoses each time. When I put it on my 2008 Ford, it cost an extra $150 for a sending unit. I have been pretty happy with it and will never buy from anyone else.
I think you should get away from the gravity flow setup. My buddy runs a TransferFlow, Aftermarket and OEM Fuel Tank Systems, and has been very happy with it. It was also about $1800, but is worth the extra money in the long run.
smittymcbay is offline
