Fuel Timing - Diesel Forum - TheDieselStop.com
Old 09-07-2009, 11:53 PM   #1 (permalink)
Fuel Timing
Does anybody know what sensors the CPU uses to determine fuel timing. Any help would be appreciated, Mike
1997 F250 7.3 LB SC,auto,3.55 LS,82,000 miles,deep trans pan, 03 SD trans cooler,3" DP,no kitty,Tymar intake,Optix gauges(pyro,trans temp,boost,coolant temp), SD intercooler W/Banks pipes, TW custom tunes
70jeeper is offline
Old 09-08-2009, 02:41 AM   #2 (permalink)
westvandude's Avatar
Guessing here but I think the main one is the CPS (cam position sensor).
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
Old 09-08-2009, 04:42 PM   #3 (permalink)
klhansen's Avatar
My Photos: (169)
The main sensor that affects fuel timing is the Engine Oil Temp (EOT)sensor. I believe it's mainly for starting, advancing timing when engine oil is cold, then backing off as it warms up.
Barometric Pressure sensor (BARO) also affects engine timing, although I don't know how it affects it. Probably advances timing at higher altitude, but that's just a guess.
The CPS only tells the PCM where TDC is, but I suppose you could say that the CPS affects timing.
Hard or no-start? Check Here
klhansen is offline
Old 09-08-2009, 10:07 PM   #4 (permalink)
Thanks guys, that will give me a place to start. klhansen, what part of Alaska is Eagle River in? I have family in and around Fairbanks. Before I had a life I spent my summers there, I really miss it.
Mike
70jeeper is offline
