FUSE # 22 f350 2002 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-05-2011, 01:01 PM Thread Starter
Red face FUSE # 22 f350 2002
2002 f350--- fuse #22 keeps blowing ??? unpluged the filter bowl heater ( was told that was for the older trucks) but did it anyway it-- changed out the-glow pug relay it started but after driving home when I turned it off #22 keeps blowing ???? any ideas guys
2002 F350 4/4 4DR LNG BED
zusmar is offline
post #2 of 6 (permalink) Old 05-05-2011, 02:39 PM
Flywheel's Avatar
Not the fuel bowl heater or GPR. Check the engine harness where it crosses the valve cover on the drivers side. If it rub through the wires there it will blow that fuse.
Hope you find it.
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #3 of 6 (permalink) Old 05-05-2011, 05:04 PM Thread Starter
Flywheel -thanks for that--so you say the harness that goes from valve cover to other or just on the drivers side going towards the firewall. Did you the same problem ?? THANKS JV
zusmar is offline
post #4 of 6 (permalink) Old 05-05-2011, 09:04 PM
woodnthings8's Avatar
Fuse 22 controls your injection pressure regulator and also the brake pressure switch. You may want to disconnect them one at a time and see if that fixes the fuse from blowing. My guess that if you are not having running issues it is the brake pressure switch.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #5 of 6 (permalink) Old 05-06-2011, 04:20 AM Thread Starter
THANKS KEN
zusmar is offline
post #6 of 6 (permalink) Old 05-06-2011, 05:07 AM
Flywheel's Avatar
No - but it has come up before....
Autoenginuity
Flywheel is offline
