Gas Pedal and Gauges do not work. - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 10-25-2006, 07:16 PM Thread Starter
My 2000 F-350 will start and idle but the gas pedal will not work and the gauges are all dead. It will only start if I remove fuse #19 which is the fuse for the APCM, Instrument cluster, GEM module, Overdrive Validation Switch, Idle Validation Switch, Overhead Console, and Diesel PCM via clutch. If I put fuse #19 in and start it it will blow fuse #24 under the hood (PCM fuse). Any ideas? What is the idle validation switch and the Diesel PCM via clutch?
Huck
02'Excursion PSD LTD, 4x4, Hypermax Stage 1+ Injectors, Hypermax H2E, Hypermax Tapercore, Hypermax 5", Suncoast, Air Raid, TS Chip, Pioneer DVD & Nav., XM, XTANT Amps & Subs in Rear Doors, Boston Seperates, PS2, 2 6" Drop Down Screens, Hellwig Sway Bar, Carbon Fiber Ultra Lite Gauges, 3" DR lift, 295/75/16 Nittos, Bilsteins & Steering Stab., (Burned To the Ground)
01' Excursion PSD Ltd. 4x4, Oxford White,3.73 LS, BTS Trans, 6.0 L Cooler, Pioneer Nav, ADS/U.S. Amps, JL Audio Seperates & Subs, Viper Remote Start, Tymar, 315/75/16, Pro Comp Stab., Bilsteins, TS 4 Pos. Chip, Hypermax Combo Gauge, 4" Exhaust, V & B Code Springs
05 Excursion 4x4 6.0L
05' F250 CC, SB, 4x4 Harley, Blue, 4 Buckets (SOLD)
00' F350 CC 4x4 Lariat Dually, BTS Trans, (SOLD)
00' 40' American Tradition Motorhome 8.3L Cummins
88' Porsche 930 Turbo Cabriolet 450 HP
99' Mercedes E300TD
Huckster is offline
post #2 of 19 (permalink) Old 10-25-2006, 07:54 PM
Re: Gas Pedal and Gauges do not work.
i don't know all of the diesel lingo you used in your post, but i can tell you i had the exact same thing happen and almost lost my mind. turns out when i was trying to check the a/c i pulled a fuse and stuck it back in the wrong spot. i know you said something about position 19. I really dont know the position, but after playing around for 10 minutes by sticking a fuse in and out of all the open sites, sure enough i found the right one and presto, everything abck to normal.
99.5 ext.cab,8ft.Bed,6spd,DP Tuner(H.I.,80e,80t,120r)AFEstage2,Zoodad,Procomp (black rims) w/285/70/16DunlopA/T, ATS Housing, CCV, AIH, Autometer 3 guage cluster, MBRP T304, Stars and Stripes rear window tint,Outside P.A. system w/ice cream truck music or police siren depending on who is stopped in front of me. 1st time diesel owner as of 9/15/06
pezrock77 is offline
post #3 of 19 (permalink) Old 10-25-2006, 09:19 PM
klhansen's Avatar
My Photos: (180)
Huck
That's really weird. I can shed some light on your last question, but you'll need a wiring diagram to track this down.
Idle Validation switch is the switch on the accelerator pedal that verifies the pedal is at idle. It's a safety to prevent an engine runaway from a problem in the accelerator circuit.
Diesel PCM via clutch would be the feed to the Clutch Pedal Position Switch. It's used to send a signal to the PCM to kill the cruise control when you step on the clutch pedal. Since you have an automatic, there's a jumper on that circuit.
Pulling fuse 19 would be why it doesn't respond to the go pedal and you don't have instruments, but I can't see why that would cause fuse 24 to blow.
OK, I dug a little deeper. It sounds like you have a short in something that's fed by Fuse 24 that's activated by the PCM. Fuse 24 feeds the coil on the fuel pump relay, and fuse 19 powers the fuel pump. I'd check for a short in your fuel pump wiring, or maybe the fuel pump relay itself is bad.
Other possibilities are GPR control circuit, Brake pressure switch.
If you can't track it down, shoot me a PM, and I may be able to help on what those circuits go to.
Good luck
), AIS,
regulated return,
klhansen is offline
post #4 of 19 (permalink) Old 10-25-2006, 09:54 PM
Definately a little goofy. But if the fuel pump fuse is pulled, and the truck runs, I would definately be looking at that relay. Does the fuse pop KOEO, or only KOER?
99.5 F350 SRW 7.3PSD 6SP CC 4x4
<span style="color: red"> autometer pro-comp pyro-n-boost, wicked wheel, Reg return, AIC mod, Exhaust brake mod </span>
banging on all 8 since 11/24/06
Tom
tlutman is offline
post #5 of 19 (permalink) Old 10-25-2006, 10:16 PM Thread Starter
Fuse 24 blows as soon as I turn the key on.
Huck
99' Mercedes E300TD
Huckster is offline
post #6 of 19 (permalink) Old 10-25-2006, 10:22 PM Thread Starter
Just to clear up any confusion. The fuse under the hood is fuse #24(PCM Power) a 20amp maxi fuse. Fuse #19 is a 10 amp under the dash. Thanks for all the help guys. I am starting to get frustrated.
Huck
99' Mercedes E300TD
Huckster is offline
post #7 of 19 (permalink) Old 10-25-2006, 10:35 PM
The only thing I can think of right now is the wiring going to the shifter overdrive cancel switch, that will typically blow CJB #19, but I can't see why it would blow BJB fuse 24. You could possibly inspect the wiring under the column shroud for the O/D cancel(this is assuming you have an automatic). I think Kevin must have gotten confused between the CJB (under dash) and BJB (under hood), One fuse does run the fuel pump relay coil, but thats as close as it gets.
If I get a chance in the AM, I'll look in the book, trying to go between screens on the DVD is not always the easiest to do.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #8 of 19 (permalink) Old 10-25-2006, 10:48 PM Thread Starter
Buddy do you by chance work at the dealer in Williston. If so that may be my next stop. I am in Crosby and need to get this thing fixed. I have to get back to NC. Have been here vistiting my grandparents.
I checked all the wiring on the column and it all looks good. Any way to test it? Thanks for the help guys.
Huck
99' Mercedes E300TD
Huckster is offline
post #9 of 19 (permalink) Old 10-25-2006, 10:56 PM
Yep, I am a tech at the dealer in Williston, can't say I expected you to be that close to me.
Buddy
post #10 of 19 (permalink) Old 10-25-2006, 11:03 PM Thread Starter
Yep my grandparents and aunts and uncles live in Crosby. My uncle owns a bar in Williston. It's been about 3 years since I have been here. Had a good time hunting and seeing relatives. The guy at the parts store in Crosby used to work at the dealer in Williston and said you were a good mechanic and I should call you. Small world. How busy are you guys down there?
Huck
99' Mercedes E300TD
Huckster is offline
post #11 of 19 (permalink) Old 10-25-2006, 11:10 PM
Fairly steady, but not extremely busy where it wears us out at the end of the day, which is very nice. I believe my schedule is fairly open, and they try to keep the other tech by me with some open time for walk-ins with concerns. Talk with either Chris or Les in service, both of them are nice to deal with, and should be able to get anything in.
Buddy
post #12 of 19 (permalink) Old 10-26-2006, 09:08 PM
I've been looking at power distribution diagrams, and your truck should not run without fuse 19. Fuse 24 supplies many items, from the gp relay, IA htr relay, PCM, IDP, etc.
what is odd is that fuse 24 is what closes the contacts on the FP relay, which gives the FP power from fuse 19. without f19 , you should not be running, idle or not. Try removing the FP relay all together and try to start it. this should split the trouble shooting to one side or the other of the relay.
If it doesn't start replace the relay with a known good one.
if it does start, let it be known.
one other thing, make sure your climate selector switch is set to off, not A/C.
Tom
tlutman is offline
post #13 of 19 (permalink) Old 10-26-2006, 09:32 PM
You are misreading the wiring diagrams, klhansen did the same thing in his post. There are two fuse boxes on the truck, each with a fuse 19. The fuse #19 BJB(Battery Junction Box under the hood) controls the fuel pump relay, etc). The CJB (Central Junction Box under the dash) controls the instrument cluster, APCM, IVS, etc, so the truck will run with no fuse #19 in the CJB.
As an update however, I got the truck in my bay somewhere around 4pm, started checking the circuits off CJB Fuse 19. After about 1/2 hour or so, found the overhead console may have been shorting. Installed fuse, started truck and runs fine. Reinstall overhead console and truck still runs fine, no problem with blowing the fuse. Working on inspecting the harnesses around where I have moved to see if any shorts or damaged wiring anywhere. I also saw the pyrometer box was tied in off CJB fuse 19, so not sure if that may have been causing the concern.
Buddy
post #14 of 19 (permalink) Old 10-26-2006, 09:58 PM
Ok, you got me on that. I'm decent with electrical troubleshooting, but got to get used to the multiple fuseboxes. So, why would a short in this blow fuse 24?
Tom
tlutman is offline
post #15 of 19 (permalink) Old 10-26-2006, 10:15 PM Thread Starter
That is good news. The last thing I was going to check was the overhead console. No way would I think that would short the PCM maxi fuse. I didn't install the pyro. My buddy I bought the truck from installed that so I didn't have a clue. Did give it a thought when fuse 19 was out and pyro was not working. But by that time I was fed up with looking at it.
Buddy did you find the fuel leak?
Thanks again everybody.
Huck
99' Mercedes E300TD
Huckster is offline
