Glo Plug relay modification - Diesel Forum - TheDieselStop.com
Old 11-25-2012, 06:28 PM   #1 (permalink)
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Will this modification give the glo plugs more to help the truck start better in colder weather? Or is it just more reliable?
Crabo is offline   Reply With Quote
Old 11-25-2012, 06:48 PM   #2 (permalink)
RT
RT's Avatar
More reliable - there won't be any more current than in a properly working standard relay - its just the standard relay doesn't work properly very long...
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 11-26-2012, 11:29 AM   #3 (permalink)
I think I have an unused relay as I deleted the AIH. I half thought about wiring two relays together in parallel to reduce the current load on an individual relay. It probably would last a good long time not placed at or near rated load on contacts.
2003 7.3 F250 SD SRW Auto DIY intake 285/70 1.5" Leveling Kit TS Performance 75 HP Chip
TTBadDog is offline   Reply With Quote
Old 11-26-2012, 01:04 PM   #4 (permalink)
I would keep it simple and change over to a Stancor. They are built to handle the current load.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster and inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline   Reply With Quote
Old 12-01-2012, 09:35 AM   #5 (permalink)
Griz, agreed but it would split the current draw between the two. In KY my GP are probably not needed year round. Am I correct in understanding that they remain on a full 2 minutes regardless of temperature of engine or ambient? If that is the case a timer or cutout based on some sort of input would reduce the total time the GP's are burning. This would allow the GP relay to live longer and possibly the GP's themselves.
Old 12-01-2012, 11:02 AM   #6 (permalink)
The PCM determines how long the glowplugs are energized (if at all) based on engine oil temp & barometric pressure. The maximum is 2 minutes.
Evel486 is offline   Reply With Quote
Old 12-01-2012, 11:19 AM   #7 (permalink)
bugman's Avatar
My Photos: (12)
Just get a Stancor and be done with it. You don't have to modify a thing for the install except for the mount if you want to but it isn't necessary.
I have been running a Stancor now for 10+ years with no problems.
bugman is offline   Reply With Quote
Old 12-01-2012, 01:36 PM   #8 (permalink)
rammertide07's Avatar
Send a message via MSN to rammertide07
I like my glow plug relay switch. I can turn the glow plugs off then start and have more juice for the starter. It turns over faster and still has heat in the cylinder. Works great for me.
Sent from my DROID RAZR using AutoGuide App
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes (Stock, 40 Tow WITH Whsiper tune, 80 Daily Driver, 100 Race, 140 Extreme, 140 smoke show)//Recon smoked cab lights/MM Hubs/Hood/HPx/FRx/GPR switch-Indicator
First vehicle (still driving): 96 F250 XLT 2x4- All factory (injectors & turbo) except straight exhaust. 570k miles
7.3 Information Zip.File 29.66MB
rammertide07 is offline   Reply With Quote
