Hey Gents. My SES light has been on for awhile. So, today I went to the dealer for the recall on the cruise control wire harness. I ask the tech, about the SES light, to see how important it is to have it checked. He said, it would cost 120.00 to pull the codes. So, I told him not to bother with it. Well after he fixed the recall, he pulled me to the side, and told me he pulled the code for me, and said it has to do with the glow plug on the middle of the driver side( he didn't tell me the code ). He thought it was, probably a bad glow plug. My question is, how hard is it to change a glow plug, and how much do they cost? Thanks, Jerry.
Once you remove the turbo boost tubes, the valve covers are accessible .Then the glowplug is next to the injector.Blow all of the oil out from around it before you remove it so the oil won't go into the cyl.If you are going to do one, I would replace them all .They are not that exspensive.Or atleast replace all on that side while you have it apart.
2000 F350 srw pickup
3 in. leveling kit,35x12.5x16.5 BFG's,K&N air filter,4 in. exhaust from turbo back,Bully Dog boost,trans temp and exhaust temp gauges,Painless wiring inline module,Western Diesel four position chip(currently out being repaired),203 thermostat,Bully Dog shift kit.
I would simply ohm test them to make sure what he is telling you is even true or not. If you need to change them they are easy, just make sure you only use Beru plugs, they make the MC plugs, Bosch and others don't last. Cost now is anywhere between $10-$15 each, they have really gone up in price!! I would also change all of them while I am in there. But I would do my own troubleshooting first!!
NCH
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCH
How do you ohm test them??? And do you have to remove the valve cover, to ohm test?
