glow plug / injector harness - Diesel Forum - TheDieselStop.com
Old 10-31-2009, 07:49 PM   #1 (permalink)
anyone have any pics of where the harness plug goes bad can't get readings on 1st 2nd and 4th on drivers side
SmokeMaker is offline
Old 10-31-2009, 07:57 PM   #2 (permalink)
JimTJr's Avatar
My Photos: (20)
So cylinder 2-4 & 8 are bad. They usually go bad under the valve cover. The good news is the drivers side is the easier one to pull. Remove the CAC tube, air cleaner intake ect... Pull the CCV filter off. (Two Phillips screws) and remove the 13mm bolts. (You'll need shallow and deep wall, and a swivel and short extention.) After you remove it, look at all the harness underneath. Probably cracked, and some burnt pins on the harness. INSPECT the valve cover gasket. If the pins look good, and it ohms fine, no problem. If there are burnt pins, it'll need replaced. To the tune of 60.00 or more for each one.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 11-01-2009, 07:13 PM   #3 (permalink)
it was unplugged latch is a poor design should i take the right side apart or wait
Old 11-01-2009, 11:45 PM   #4 (permalink)
Do it when you can as soon as you can. i.e. nice weather day if you have to do it outside etc. If you catch it (and secure the harness) before it has a chance to burn the pins you are money ahead/saved!
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
Old 11-07-2009, 11:58 AM   #5 (permalink)
used the ford fix 3 little pieces of plastic worked great even made a click when putting it together hope this helps someone
