Glow plug relay - Diesel Forum - TheDieselStop.com
Old 03-08-2010, 07:36 PM   #1 (permalink)
Glow plug relay
I got a new glow plug relay. I connected the wires that were on the big post the same way that was on the old glow plug relay. I did the same with the small post. Have current to all post but one of the big post. Tried a cold start, turned on the ignition, wait to start engine light on, and check the post that did not have power. Still does not have power.
Whats up?
Oh, I have put in all new glow plugs
nealtahoe is offline
Old 03-08-2010, 07:54 PM   #2 (permalink)
RT
RT's Avatar
One of the small posts should have 12V+ all the time, the other is grounded by the PCM when you initially turn your key on. That closes the relay between the large positive lead, and the large lead that goes to your glow plugs.
RT is offline
Old 03-08-2010, 08:16 PM   #3 (permalink)
FYI: Your GPR and Wait To Start Light are not on the same circuit. You can have a Wait to Start Light and not have the GPR on and visa vera. Watch the voltage Gauge, when the glow plugs turn off you will see it jump up a few volts.
If your engine is warm your GPR will not turn on.
Wayne B
2000 F-250 Super Duty 4x4, Auto, Super Cab, Long Bed.
http://tinyurl.com/nguxnv
My other vehicle:
Piaggio MP3 500
WayneB is offline
Old 03-08-2010, 08:44 PM   #4 (permalink)
My Photos: (35)
I have learned over winters to watch that needle or the scanguage , when the glow plugs are done, the needle will climb and the scangauge will come on, then it is ready to start..
If the engine is cold that all takes longer, when it is warm shorter... when hot no time at all...
Winter is here again, and yes I mean WINTER.. the temps are likely to reach -25F and then there is the snow and the dark.
2000 E350 7.3PSD, Hellwig Stablizer bar,140 Lightforce with covers, 55Watt High/Lows HID's , extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E Toyo Open Country, My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
IT IS MINE ALL MINE.....(The Van that is, it has been Released by Lenholder)
Alaskapsdvan is offline
Old 03-08-2010, 09:38 PM   #5 (permalink)
428INTERCEPTOR's Avatar
Did you double check to ensure it's a 12V, not a 24V. I chased my tail for most of a Saturday chasing wires until I discovered I ordered the wrong Stancore relay....the 24V one.
Opps....
2002 F-350, 4X4, LONG BED, CREW CAB, LARIAT (7.3 POWERSTROKE OBVIOUSLY)
GRAND JUNCTION, COLORADO
428INTERCEPTOR is offline
