glow plug relay ? - Diesel Forum - TheDieselStop.com
Old 12-26-2012, 01:33 PM   #1 (permalink)
Americandiesel9's Avatar
glow plug relay ?
My truck is a huge pain in the #$$ to start when cold smokes like hell well i noticed this morning when i turned the key on the glow plugs dont drawl anything so i check the relay today at lunch listen for the click no click got volt meter out checking post and have 12 v when key is on and the other side has 12v to any ideas also the truck feel very laggy like whe. You go to accelerate it hesitates then picks up and is gone
SOLD BUT NOT FORGOTTEN 97 f350 cc lb 4x4 5 speed 260000 mostly stock 6in lift 37" Goodyear mud tires, k&n air filter, straight exhaust with 3" dp
2005 chevy 3500 duramax crewcab dually 4x4 270000 (sold)
1999 dodge 2500 club cab 24vcummins 4x4 auto 569000(sold)
2000 f250 7.3 4x4 6 speed single cab pretty much stock no muffler no cat with Diablo tuner 350000
Americandiesel9 is offline   Reply With Quote
Old 12-26-2012, 01:37 PM   #2 (permalink)
RT
RT's Avatar
If you are getting 12 volts to both lugs then your glow plugs are likely burned out. You can pull the harness and ohm them out.
Sent from my iPhone using AutoGuide.com App
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is online now   Reply With Quote
Old 12-26-2012, 02:24 PM   #3 (permalink)
Yea im gonna try that tonight
