glow plug/relay replacement labor cost - Diesel Forum - TheDieselStop.com
Old 03-28-2008, 03:40 PM   #1 (permalink)
How much time should it take to replace the glow plugs and relay? I do not have a garage to work in and it's damn cold and snowing hard, So...I called a local garage who also tows with all F350's and they quoted me 4.5 hours..thats $275.00! I was figuring about 2 hours MAX! Am I wrong?
Deano
Early 1999 (2/1998 build) F350 Lariat, 7.3, 6 speed manual, Crew, Dually, 4x4, Pac Brake, Banks intake & waste-gate actuator, Banks 4" stainless exhaust, Banks Pillar Turbo & Exhaust temp gauges, 230,322 miles
HeavyD2002 is offline   Reply With Quote
Old 03-28-2008, 03:50 PM   #2 (permalink)
klhansen's Avatar
My Photos: (175)
Working by your self, 4.5 hours wouldn't be a bad guess for replacing glow plugs, IMO (especially in the cold). The relay itself is a 15 minute job including prep and cleanup, but there's lots of stuff that has to get out of the way to get the valve covers off.
Make sure that your GP's actually need replacing before tearing into it. Check the link in my signature for how to do that. It'll take maybe 30 min to check them, potentially saving that 4.5 hr job.
Hard or no-start? Check Here
Old 03-28-2008, 04:00 PM   #3 (permalink)
Sure did...already been there....Had the white smoke in the am on cold days, then pulled the connector and had two plugs that resistance showed were bad. The Wellman GP's I bought came with the relay as a package.
Thanks!
Dean
Old 03-28-2008, 04:18 PM   #4 (permalink)
klhansen's Avatar
My Photos: (175)
Originally Posted by HeavyD2002 View Post
The Wellman GP's I bought ......
Oooohhh, Most of the guys here recommend sticking with Ford Motorcraft or International GP's (they're both made by Beru and have that etched on the barrel). There have been too many horror stories about swelling/broken tips on aftermarket GP's to take a chance on them. I don't know the Wellman brand, but hope they work out for you.
Old 03-28-2008, 04:34 PM   #5 (permalink)
best glow plugs
Huh....I have found numerous positives for Wellmans....I'll let you know!
Deano
Old 03-28-2008, 08:57 PM   #6 (permalink)
My Photos: (9)
took me about 6 hours, sitting on top of the engine. but i cleaned alot of stuff as i went. if it was just to replace them, i'd bet on at least 4 hours.
kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a stock p-stroke exhaust on the end of it 25xxxx miles, amsoil bypass, coolant filter, 08 Diff cover
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, High flow outlet, trans, pyro, boost gauges, DP Chip, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, amsoil bypass, 08 diff cover "OEIS", b&w 5th wheel companion
21xxxx mileshttp://photos.thedieselstop.com/show...0/ppuser/46897
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH?
H O N D A - How Odd No Damn Acceleration
radeon1314 is offline   Reply With Quote
Old 03-28-2008, 10:44 PM   #7 (permalink)
klhansen's Avatar
My Photos: (175)
best glow plugs
Deano
I hadn't seen that for Wellmans, but that's a good sign. I know that there have been negative posts for some other brands (I think Autolite was one). Haven't heard of anyone having problems like swelling or broken tips with Motorcraft or Int'l GP's.
Sounds like you're good to go.
