Glow Plug relay and wait to start light - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-03-2010, 09:04 PM Thread Starter
Angry Glow Plug relay and wait to start light
New member to the diesel stop.
Last week my glow plug relay went out. Third relay in 2 years. Read about people installing the heavy duty Stancor as a replacement. Well I wanted to get the truck back up and running did not want to order the Stancor and wait for it to show up. In my search for a replacement I decided to try a solenoid from Napa, part #st36 Store Locator | NAPA Online
Hooked everyting up last Thursday night and the truck starts great on Friday. I left the truck sit for 4 days (away on business trip) and when I return the batteries are dead. I hook up the battery charger for 2 hours and try to start. No wait to start light. I start checking for blown fuses. Not a single blown fuse inside cab or under hood. Start swapping out relays and still no wait to start light. I use my MCSP to read codes and there are none.
Next step was to check at the GPR itself and discover that my ground wire from PCM is hot. So now I have 3 hot lines at the GPR reading 12 volts. I decide to unhook bothe small wire at GPR and my wait to start light comes on when I turn the key. I decide to hook up the small wire from the ignition and then used jumper cables to supply juice to th glow plugs. The truck starts up and all is fine.
Can someone explain why my ground wire from Pcm was hot and why the wait to start light was not working?
Sorry for the long post, but this one has me stumped.
99.5 f250
Microchip Supertuner
6637 intake mod
h2ologd is offline
post #2 of 5 (permalink) Old 03-03-2010, 09:24 PM
klhansen's Avatar
My Photos: (180)
If you turn the key on with the engine cold, power is sent to one small terminal of the GPR and the other small terminal is supposed to be grounded by the PCM to activate the relay. If you got 12V on both small terminals, it means that the PCM isn't completing the circuit.
The relay you got apears to be correct, in that it's a 4 terminal relay. I'm assuming it's not internally grounded, but if it were, it would be keeping your GP's on all the time. That would definitely kill your batteries.
The PCM is sensitive to low voltage and won't "turn on" if the voltage isn't high enough, so maybe that's why you didn't get a WTS.
Disconnect all the wires from your GPR, and check with an ohmmeter and see if each one is isolated from ground. There should be some reisistance across the two smaller terminals, but both should be isolated. If you find something wonky there, you should get another GPR. If you have an International dealer nearby, get one from them for around $30. Part #1831646C1
), AIS,
regulated return,
klhansen is offline
post #3 of 5 (permalink) Old 03-03-2010, 09:34 PM Thread Starter
Appreciate the reply. Maybe the voltage was too low, but I had the charger on while trying to start and it turned over real fast. I did fail to mention in my post that while I was checking for codes I tried to return the programming to stock setting. The scmt could not do it. Right away I am thinking the pcm is bad.
After getting the truck started I ran it for 20 miles and it ran great. Did not get to troubleshoot any tonight. Wanted to wait until the motor was cold.
99.5 f250
6637 intake mod
h2ologd is offline
post #4 of 5 (permalink) Old 03-04-2010, 06:53 PM Thread Starter
Just an update on my problem. Had a chance to check over the gpr tonight and everything is working fine. Wait to start light also works. I was also able to reprogram the truck so I think the pcm is also fine.
Not sure what drained the batteries and caused all of the problems. Hopefully it does not return
99.5 f250
6637 intake mod
h2ologd is offline
post #5 of 5 (permalink) Old 03-04-2010, 08:12 PM
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
I believe they list for $32.68. I got mine for around $28.00. I got MOS, discount on all the parts I purchased yesterday. If you're not in a pinch I wouldn't bother with your FORD dealer they list for $62 $66.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
« turbo | Gpm »
