Originally Posted by elvia
On the gpr, should BOTH small wires send power to the glow plugs or just one?
When turning on the key, I get power to the back small wire. No power to the front small wire at any time. 12v at both large wires.
What is the front wire for, if not for glow plugs?
The small terminals on the GPR are the control circuit, one being fed via a key-on hot fused circuit, and the other one grounded by the PCM. So if you never get any voltage on one of the small terminals, then the relay coil is burnt out.
The large lugs are what carry the power to the GP's. That's the whole point of a relay - Use a low amp circuit (small wires) to switch a much larger load. There's no way the dinky wires on the control circuit could feed the 100+ amps that the GP's draw. You'd be seeing smoke if you tried that.
Check the Hard/No Start link in my signature for how to check your GP system, but from what you describe, I'll just about guarantee your GPR is shot.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
