Glow plug torque spec. - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-09-2005, 12:40 PM Thread Starter
I understand a dab of anti-seize and the proper torque is necessary to do the job right. What's the method and torque. Thanks for the help.
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
shamuex2000 is offline
post #2 of 8 (permalink) Old 03-09-2005, 12:46 PM
klhansen's Avatar
My Photos: (180)
Re: Glow plug torque spec.
The service manual says 14 lb-ft for glow plugs and doesn't mention using anti-sieze. There's a tapered seat at the bottom of the threads that makes the seal, so the threads will be bathed in oil from above. Anti-sieze probably not necessary.
), AIS,
regulated return,
klhansen is offline
post #3 of 8 (permalink) Old 03-09-2005, 02:46 PM Thread Starter
Should have known you guys from the Great White North would know about glow plugs. Thanks, Dale
Chicago MOB member.
post #4 of 8 (permalink) Old 03-09-2005, 05:22 PM
klhansen's Avatar
My Photos: (180)
Whadda ya mean, Great White North?? I live in the Bananna Belt if you talk to some of the guys from the Interior. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Glad to help.
), AIS,
regulated return,
klhansen is offline
post #5 of 8 (permalink) Old 03-09-2005, 05:40 PM
I was looking up the torque specs for my new injectors in the service manual and checked the glow plug specs while I had it open. It reads 124 in/lbs or 14 Nm. Might want to double check before you torque it down.
SOLD.
2000 F250 C/C Lariat, Beaner hybrid singles, DP Tuner tuning, H2E , SPDiesel TC controller, custom intake, 5" exhaust, MB, Zoodad mod, tank mods, harpooned, ITP regulated fuel system, DI HX crossover, Autometer gauges, Red Line oils. 381/755 Kauffmans 10/15/05...on hybrid split shots.
New ride.
1994 Escort 4 door, stick, 82,000 miles, owned by a little old lady. 42.5 hand calculated MPG highway.
bct222 is offline
post #6 of 8 (permalink) Old 03-09-2005, 06:25 PM
fordmastertech's Avatar
I come up with 19 Nm or 14 LB/FT for the glow plugs.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #7 of 8 (permalink) Old 03-09-2005, 06:49 PM
FordMastertech,
Checked again says 14Nm. I would be inclined to believe you however. It is a Ford shop update manual but it was printed for the 99 model. Don't know if there were any updates made or if this thing is wrong. Guess you can't believe everything you read. What should the injector hold down clamp mounting bolt be torqued to? This thing says 120 inch/lbs [img]/ubbthreads/images/graemlins/shrug.gif[/img]
SOLD.
New ride.
bct222 is offline
post #8 of 8 (permalink) Old 03-10-2005, 09:51 AM Thread Starter
We should really have a data base on torque specs/nut sizes and International PN's. We could all post there after doing jobs like this. That would be nice. Thanks for the replies. Dale
Chicago MOB member.
