glow plugs! - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 11-30-2012, 10:54 PM Thread Starter
glow plugs!
Having a bit of a starting issue. Hard start and white smoke. Kind of hard to get a handle on as temps have been up and down, just trying to get some ideas of things to look at. I have new batteries and a new gpr. How many amps will will the glow plugs pull when cycled on? Do they pull more the colder the temp is? I searched the form but all I found were ohm readings for the glow plugs themselves.
2000 f3504x4, cc, lwb, 7.3, K+N air filter, ATS three stage chip, 4" ss turbo back exhaust, dual outlet ss muffler, 5" polished tips, Pace 17x9 wheels, mt baja atzp3 37x12.5x17, Fabtec 5.5" lift, 2002 headlights and markers, stereo and video !
w3504x4m is offline
post #2 of 4 (permalink) Old 11-30-2012, 11:27 PM
ReefBlue's Avatar
Should be somewhere between 100-200 amps or more depending on actual resistance of the individual plug. ohms x voltage=current
They don't draw more current if it is colder, they just stay on longer at their normal draw.
1999.5 F250 creeping up on 400k.
Check your wiring harness: Chaffed wiring at driver's valve cover.
Keep everyone (and yourself) updated:7.3 mileage and repair thread
If you insist on throwing parts at your truck to fix the problem, go big--don't forget the driver's side frame rail.
If your ICP connector has oil in it, change it. Don't argue, just change it. Don't check other things first, just change it.
ReefBlue is offline
post #3 of 4 (permalink) Old 12-01-2012, 03:36 AM
Spec for GPs are .3 to .5 ohms. Since there are 8 in parallel, that's .037 to .0625 ohms. Using this range of resistance and ohms law to solve for current (i=e/r) assuming 12 volts, that's 12V/.037Ohms=324 Amps to 12V/.0625Ohms=192 Amps. To calculate the power in watts use (p=i*e), or 3888W to 2304W. In theory, the hotter the GP gets the higher its resistance becomes (less current draw). The difference in initial current draw between a 70F and -20F GP is minor when you consider an energized GP reaches about 2000F. Normally when GPs fail their resistance increases, so anything above .5 ohms is considered bad.
2011 F450 King Ranch, Royal Metallic Red, BW Turnover Hitch, Torklift Camper Tie Downs, Air Lift LoadLifter5000 Bags w/ WirelessAIR
Early 99 XLT F350 4X4 SuperCab Long Bed SRW
Mods: AIS Intake, BTS tranny, DP Tunner, Isspro A Pillar Trans Temp, Boost, Pre Turbo EGT, 19.5" Vision Heavy Hauler Wheels, Dunlop SP461 Tires, GTP38R Turbo, Non EBPV Turbo Pedestal, DI Intercooler, DI Uppies, DI HP Oil Cross-over, DI Regulated Fuel Return, BW Turnover Hitch, Rear Hellwig Stabilizer Bar, Rear Timbren Suspension, Moog Ball Joints, 2009 Al Rear Diff Cover, Banks 4" Monster Exhaust with Power Elbow, Torklift Camper Tie Downs, Tekonsha P3 Brake Controller
bigassredtruck is offline
post #4 of 4 (permalink) Old 12-01-2012, 11:27 AM
bugman's Avatar
My Photos: (12)
Factory specs for a good ZD-11 glow plug from the Ford manual is 0.6-2 ohms for a good glow plug.
bugman is offline
