Glow plugs not turning on . - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 10-28-2006, 01:33 PM Thread Starter
Over the last couple weeks I have been having a hard start problems.
Normally after it sits over night , but not always.
I have noticed that when it starts without problems, when I turn the key to the on pos. the voltage gets yanked down some by the glowplugs being on.
When it wont start, the voltage never pulls down. It will crank with no problems put never fire. Today I put a jumper on one of the glow plug relays and watched the voltage. It pulled down as I acspected.
I tried to start it and it fired a couple time but it wasnt having it cuz the other bank of the motor didnt have the glow plugs on a I assume.
Could someone tell me what controls the GP relays.
Or, is there any advice on where I should start.
Ive gave up and come back 5 min. later just to try it and they start working again and it fires up with no problem.
89shortbox is offline
post #2 of 4 (permalink) Old 10-28-2006, 05:48 PM
klhansen's Avatar
My Photos: (180)
Re: Glow plugs not turning on .
Welcome to TheDieselStop [img]/ubbthreads/images/graemlins/smile.gif[/img]
Check Here for the scoop on the glow plug system.
There's only one Glow Plug Relay, so if you jumpered the right one, all your GP's should have worked, not just one bank.
The relay toward the front is the Intake Air Heater relay, and would also cause the voltage to pull down. It heats the intake air for extended idling in cold conditions, but not for starting. If you heated it up with your jumper, it would help starting, but not nearly as effective as the glow plugs.
Your GPR probably has bad contacts and works intermittently if it started OK 5 minutes later.
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 10-28-2006, 06:51 PM Thread Starter
thanks for the reply and the link. Very helpfull.
I went to my buddies shop and printed off schematics and troubleshooting info for the GP circuit. Im glad you stated which relay is the GP relay cuz the pictures and schematics just say "top right of engine". That dont help when they are next to each other on the same side of the engine.
I learned the computer feeds power to the GP relay activation circuit and then the GP controller grounds the GP relay activation circuit.
Pretty goofy.
I will be playin with it tommorow.
Again, thanks for the info.
post #4 of 4 (permalink) Old 10-28-2006, 07:24 PM
klhansen's Avatar
My Photos: (180)
Pretty goofy.
Not really that goofy, The control circuit of the GPR is fed power thru a key-on hot circuit, and the circuit is completed (to ground) by an electronic switch in the PCM. That's what pulls in the relay.
The GP controller only exists on some California trucks and most (all?) Excursions, and if you have a GP controller, then you won't have a GPR.
Glad I could help out.
), AIS,
regulated return,
klhansen is offline
