Grinding when towing and turning. - Diesel Forum - TheDieselStop.com
Old 01-01-2013, 02:35 AM   #1 (permalink)
rammertide07's Avatar
Send a message via MSN to rammertide07
Just got back from a Christmas trip and pulled my 14' flatbed. I noticed that when pulling it and after, I have a grinding feel when I turn. I think its something to do with the friction modifier but taking input.
Thanks and happy new year to everyone
Sent from my DROID RAZR using AutoGuide App
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes (Stock, 40 Tow WITH Whsiper tune, 80 Daily Driver, 100 Race, 140 Extreme, 140 smoke show)//Recon smoked cab lights/MM Hubs/Hood/HPx/FRx/GPR switch-Indicator
First vehicle (still driving): 96 F250 XLT 2x4- All factory (injectors & turbo) except straight exhaust. 570k miles
rammertide07 is online now   Reply With Quote
Old 01-01-2013, 11:04 AM   #2 (permalink)
Rear Grinding.
I have a 03 4x4 and it has always done the same thing. I had the oil changed but it still does it .I sure wish someone with the answered you .
indian347 is offline   Reply With Quote
Old 01-01-2013, 11:12 AM   #3 (permalink)
Could be the modifier, could also be a differential carrier bearing or rear wheel bearing. At any rate sounds like time for an inspection and fluid service change. Or, you could do it the cheap way and just add 2 oz of modifier at a time and see if that clears it up.
2002 F250 7.3L PSD, bought new now at 202K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline   Reply With Quote
Old 01-01-2013, 11:18 AM   #4 (permalink)
Thanks Oneof6. I think I'll try adding the friction modifier little at a time, after the ground dries up.
Old 01-01-2013, 12:01 PM   #5 (permalink)
Think I found the problem. Went to go meet my wife at the end of the flooded roads, went to go lock my hubs in....THEY WERE ALREADY LOCKED!! And have been for about 2500 miles. I consider myself luck to still have a functioning transfer case. I drove at some points 80-95mph.
Old 01-01-2013, 02:02 PM   #6 (permalink)
91diesel's Avatar
So you unlocked it and it went away? Guess im missing how the hubs being locked is going to hurt anything. Your transfer case was in 2wd, no?
2000 F250 4x4 ZF6
91diesel is offline   Reply With Quote
Old 01-01-2013, 07:19 PM   #7 (permalink)
Yes, didn't notice it after unlocking. The transfer case was not built for high highway speeds. Locking the hubs locks the wheel to the axles, which is tied into the front drive shaft. Only thing switch the truck from 2wd to 4wd is to connect to drive line from the transmission to the transfer case.
Old 01-01-2013, 07:30 PM   #8 (permalink)
91diesel's Avatar
Mine have been locked since it started snowing a lot two weeks ago and i drive 65-70 most of the 60 miles to work. I think I would check all the u joints good.
2000 F250 4x4 ZF6
Old 01-01-2013, 08:01 PM   #9 (permalink)
It can be done on day to day basis. Just more wear on everything. I know a guy that drove 100mph with his hubs locked in and exploded his transfer case.
Old 01-01-2013, 10:23 PM   #10 (permalink)
tattoocharlie's Avatar
My Photos: (5)
i think ill be unlocking mine(still icy in omaha)until we get more snow
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline   Reply With Quote
Old 01-02-2013, 09:19 PM   #11 (permalink)
Would you describe this noise/vibration? I'm having a similar issue on taking off from a stop and turning, and I'm also thinking it was in the final drive. But I'm also experiencing a rumbling vibration, similar to running over road-side warning rumbles, but only on throttle-off. AND I'm noticing a decrease in fuel economy.
Any easy way to test this short of putting it on a lift? Getting damn cold outside too.
GA
Latest: '00 Excursion Limited, 7.3 P/S
Sold: '99 E-350 15-pass 6.8L V10
gregamy is offline   Reply With Quote
Old 01-02-2013, 10:15 PM   #12 (permalink)
GA
Hold the brakes and put the truck from drive to reverse. If you feel a **clunk** its probably the ujoints. Try locking and removing your front hubs, if you have a 4x4. Check for play in the center axle bearing...I've heard it called swing bearing, hanger bearing, and carrier bearing. You can also pull the plug on the differential and see if it has any metal shavings on it. You can also jack the tires up and see if they wiggle.
My is kinda lick you described, running on the edge of the road....slowly as I was turning.
Old 01-02-2013, 10:22 PM   #13 (permalink)
I know a guy that had his hubs locked for over a year. He did not know it. I noticed the u-joints spinning and told him. He said it had been a year since he used 4wd. Just more drag probably.
1999.5 F350 CCLB 7.3L auto 4x4 189,000 miles, Hutch mod, HPX, FRX, 4" exhaust. All stock otherwise.
04 GMC 3500 4x4 dually LB7 duramax- Sold
04/04 F250 12/20/03 build date, XLT Supercab longbed 6.0l, 4X4, 3.73lsd, FX4 pkg, torqueshift, ESOF, silver/med. flint, 6cd, back up sensors, rear slider, camper pkg, big mirrors w/ heated/pwr glass, 120k Sold
04/04 F350 Crew Cab long bed 6.0L lariat FX4 46K Sold
1998.5 Dodge 3500 4x4 dually 24valve cummins 160K (sold)
2005 Lance 835 Cabover Camper
1999 Sanger DXII ski boat
1975 Dodge RamCharger (sold)
1990 Sanger DX ski boat
1991 Dodge W350 Cummins SRW 215K(sold)
pwrstrokn2004 is offline   Reply With Quote
Old 01-05-2013, 09:43 PM   #14 (permalink)
Pulled the locks off today and they seem fine: they lock when manually locked and spin free when not. Is it safe to run with the locks off for a short test run (5-10 miles?) to verify these are not the issue? - GA
Old 01-05-2013, 10:56 PM   #15 (permalink)
Yes
