Gutting EBV - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-02-2009, 11:25 AM Thread Starter
mbohnenkemper's Avatar
Gutting EBV
I've seen people gutting the EBV and I have a stupid question surrounding this. What are the benefits and draw back in gutting the ebv? I'm having to replace leaking oil seal around my turbo, I figre I'm already there might as well. I just didn't know what the purpose was other than better flow but what draw backs there were in doing this.
mbohnenkemper is offline
post #2 of 6 (permalink) Old 09-02-2009, 01:42 PM
woodnthings8's Avatar
Here is some info on the EBPV and what it does.
exhaust backpressure valve?
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 6 (permalink) Old 09-02-2009, 02:26 PM Thread Starter
Seems like more a of a hassle to remove it for what you get out of it if that made sense. I understand making the restriction of air flow but just seems like a lot for work for not much gain. Am I off on that?
post #4 of 6 (permalink) Old 09-02-2009, 03:03 PM
69mach1377's Avatar
Some people will remove anything that looks like an obstuction, like this piece and the IAH, IIRC.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, otherwise mostly stock.
Jayco 26BHS elite, no RV parks...just the woods.
69mach1377 is offline
post #5 of 6 (permalink) Old 09-02-2009, 04:58 PM
aklim's Avatar
A "gain" if you will, is that you can do it at a time of your choosing. When the EBPV leaks, it could be at the time most inconvenient to you. In my case, it was the middle of winter.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
post #6 of 6 (permalink) Old 09-02-2009, 05:26 PM
Flywheel's Avatar
If you have a stock truck - you will not likely get any benefit from gutting the EBPV. When you start to open up things like intake, larger turbo / housing. exhaust, then there can be a benefit from eliminating it.
Also, keep in mind that when the valve is open, the plate is parallel with the air flow. The airflow is spinning and so it it a greater air disturbance then just the reduced outlet area.
Eliminating this piece can lower drive pressures and lower EGTs.
I used to use mine for the brake and for manual activation to keep the engine warm while sleeping in the winter in the - worked great for this. I cannot say how much removing it impacted my engine as I put a new turbo on at the same time. maybe not that much - but when towing at 105F, i'll take any reduction in EGTs!
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
