Hard Start / No Start when warm - Page 4 - Diesel Forum - TheDieselStop.com
Old 12-11-2009, 09:27 PM   #46 (permalink)
tbpower's Avatar
I would look back at the post I had earlier in the thread about troublshooting the hpop oil pressure. Mr Hansen also suggested the same to isolate it.
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
Old 12-11-2009, 09:39 PM   #47 (permalink)
CPUNeck's Avatar
My Photos: (13)
Originally Posted by wallysheata View Post
Started romping on it after 3 miles, i lost boost, then fuel, and the truck died.
Ok, so while it was running, how was it running. Like normal? Similar power, response, smoothness? Did the temp gauge come up to where it normally lives?
When you were losing boost, was it gradual with steady throttle? Did it sharply fall off.
How do you know you lost fuel, do you have a gauge, could you here the pitch of the engine change from a knock knock, to more of a clack clack?
Really weird, if all this happened rapidly, I'd be looking at the electronics, if gradual, it could still be mechanical problems (HPOP) If you do replace that, get with Bob, he's the man... I have one and love it! I have lots of pics from my install if your interested.
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
SVO Conversion Updated SVO stuff
CPUNeck is offline
Old 12-12-2009, 03:00 AM   #48 (permalink)
Vaquero45's Avatar
Check PM.
2002 F-350 SRW CC LB A/T 4X4 7.3 White
BTS VB and fine tuning; BD Pressure Lock
DP-60T,80E,100,120
ISSPRO EGT & Boost
-Mistake- 2001 Dodge RC Flatbed 4X4 Cummins HO 6spd (Owned 3 months)
-Sold- 2000 Lightning White
-Sold- 1995 F-250 RC 4X4 5spd 5.8 White (shoulda kept it)
Vaquero45 is offline
Old 12-12-2009, 02:14 PM   #49 (permalink)
I was going stop/go and trying to romp on it every stop light to help blow the excess oil out of the cylinders. I got caught up in some traffic and had to behave, then i had an opening, and went to punch it, i noticed no boost and it was not responding, but still running, this lasted maybe 1/4 mile, then the truck just cut out, and i coasted to a stop. I thought maybe it was the cps, but it was somewhat gradual in the sense the truck was still running, but very very poorly for a 1/4 mile then died, before that, it ran just fine and seemed normal
2002 F350 CC LB 6spd 4x4 7.3 Tow Rig - RE 2.5" Leveling Kit, 285/75-18's Toyo A/T's, factory 05 18x8's DP-Tuner 60hp-80hp-120hp settings, 3.5" Downpipe/4" Magnaflow Exhaust & Isspro Boost/Pryo.
TJ-7 Buggy LQ4 6.0L/4L60E/StaK 3spd, 1 ton's & 40's.
wallysheata is offline
Old 12-12-2009, 08:00 PM   #50 (permalink)
klhansen's Avatar
My Photos: (169)
That sure sounds like a lack of fuel to me. These trucks will still run without a working fuel pump if the fuel system is tight, as the injectors are little tiny pumps and will draw fuel from the tank. But they can't develop any power without the fuel pump to force feed the injectors (so to speak).
Recheck your fuel delivery. Be sure the pump is running (reset button at the passenger's kick panel), and open the drain valve then turn the key on to check for a good healthy flow.
Hope that fixes it for you.
Hard or no-start? Check Here
klhansen is offline
Old 12-12-2009, 08:04 PM   #51 (permalink)
CPUNeck's Avatar
My Photos: (13)
Hey for giggles, how much fuel do you have in the tank right now?
CPUNeck is offline
Old 12-13-2009, 11:05 AM   #52 (permalink)
Hey for $#*& and giggles, how much fuel do you have in the tank right now?
a little over 3/4 of a tank
Are you talking about a reset button that i press? when you say pass kick pannel, i'm thinking something inside the truck in the pass footwheel area under the glove box along the fender? I'll check the drain plug this afternoon. It's stuck over at my inlaws right now and haven't been over there since Friday afternoon.
Old 12-15-2009, 07:15 PM   #53 (permalink)
Vaquero45's Avatar
Any luck Wally? I'm interested in what the culprit is.
DP-60T,80E,100,120
ISSPRO EGT & Boost
Old 12-15-2009, 09:46 PM   #54 (permalink)
klhansen's Avatar
My Photos: (169)
Yep, that's the one. There's a hole that you reach down thru to push the reset button. It's supposed to trip if you hit something hard enough, but could have dropped out without an impact.
klhansen is offline
Old 12-21-2009, 09:03 AM   #55 (permalink)
Well finally got the truck back in good running order. Turned out to the be a bad HPOP. It would only build 175psi trying to start, and would occasionally spike to 700psi, and drop back down. I would like to personally thank the Ford Dealer here in town Western Slope Ford, for not doing a competent job in diagnosing the problem, and sending me on a wild goose chase, replacing the IPR Valve $300, Injector Orings, Glow Plugs, glow plug relay and UVCH, as well as their $200 diagnostics fee
After speaking to quite a few people about powerstroke repair shops in town, i ended up taking it over to Mercer automotive to have them go through it. I suspected it was the HPOP, but most people in the industry said those rarely go bad, so before i went out and dropped $800 on a new HPOP, i wanted a shop to thoroughly test it. Mercer did, and got it running again If the Ford Dealer had done their job correctly, they would have tested the pump as soon as they found a High Preassure Oil leak in the system, but instead, they made some assumptions and sent me on my way Alll of those things were probably not bad maint items, it just frustrates me that i paid that fee to have em look at it, and they got it WRONG, and they are the damn dealer
