hardly any boost. ran perfect 2 hours previous - Diesel Forum - TheDieselStop.com
Old 07-03-2009, 01:14 PM   #1 (permalink)
i drove into town which is about 15 miles round trip country roads. i installed a ts 6 postion a week ago and i was making about 20-25 lbs boost full throttle.(i have boost and pyro guages) i got home and parked and 2 hours later left to go see a movie and noticed it didn't have much acceleration so i checked guages and found i only had about 5 lbs at full throttle. does anyone know what i could check or have any ideas of what could cause this?
taylorfettig is offline
Old 07-03-2009, 02:34 PM   #2 (permalink)
I'd check for blown/split boots ..
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
Old 07-03-2009, 04:08 PM   #3 (permalink)
Could be bad turbo too. Mine ran fine when I parked it, 0psi boost the next morning when I started it up to go to work. Getting any white smoke? Any oil in the exhaust? If oil in the exhaust it may not make it all the way to the tail pipe if u have a muffler.
2002 F-250 XLT PSD 4x4 CC LB.
285/75/16 BFG Allterrains.
GTP38R BB Turbo.
AIS intake.
ISSPRO EV Gauges: Pyro, Boost, Trans temp.
4" MBRP turbo back.
DP Tuner: 1,200HI, 80E, 120R, 80tow, 60tow.
Overboost Annihilator.
ISSPRO Turbo Temp Monitor.
IH Bellowed up-pipes.
BTS 4R100. -10/11/2010
diablo53 is offline
Old 07-03-2009, 07:01 PM   #4 (permalink)
woodnthings8's Avatar
Have you checked your chip on other settings or back in stock? I would venture to say it is electrical vs mechanical but anything can happen. Make sure your chip is fully seated on the circuit board too.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
