Harmonic balancer puller bolts thread size - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-19-2012, 04:37 PM Thread Starter
The Harmonic balancer puller from Auto Zone comes with 3/8 by 24 coarse and fine thread bolts, already messed up threads on end of one of the coarse thread puller bolts, none of the Part stores have a Harmonic balancer in stock so I can check the threads on a new one.
Searched online and in hear, the only posts I found were unanswered.
I can't believe no one knows which threads, coarse or fine!?
99,7.3workhorse is offline
post #2 of 4 (permalink) Old 03-19-2012, 04:40 PM
chuckster57's Avatar
I'm not home to check, but my set from Harbor Freight has SAE and Metric bolts.
Sent from my Autoguide iPhone app
Train Horns:
PM please not visitor message
chuckster57 is online now
post #3 of 4 (permalink) Old 03-19-2012, 05:16 PM
RT
RT's Avatar
I'm almost sure they are 3/8 - 16 bolts. You might need to run a tap into it to clean out the accumulated gunk/dirt - they are usually pretty nasty in there.
Edit - ok, I admit it, I was bored - I went out and ran a 3/8-16 tap into mine - fits perfectly.
RT is offline
post #4 of 4 (permalink) Old 03-19-2012, 07:51 PM Thread Starter
Thanks RT, they were 3/8 - 16, nasty was an understatement, 350K of US and CAN salt took its toll. I had trouble getting a thread chaser through them. The rubber looked pretty good though, I wonder if they go bad more in hotter climates? I melted a ruler on my dashboard once driving through Phoenix AZ into the LA area , AC needed charged and wouldn't cut the mustard. I spend more time running into Western CAN from IN.
I am trying to get that oil pump off there to see if it looks like the source of my metal in the HPOP reservoir and injectors.
