Heat shield ..Is it ok to remove?? or does it really help your tranny stay cool? - Diesel Forum - TheDieselStop.com
Old 05-15-2005, 07:16 PM   #1 (permalink)
I was doing some tranny work and had to cut some of the heat shield away...Will this make my tranny temp too hot or will it be ok cut away?I was doing some tranny work and couldn't get to the top of the tranny so I cut the heat shield away next to the tranny...
2005 F-250 6.0 Blue CC.,DVD,Kicker 500.2,2-10 P3's Boston Components..
jbgarner12@msn.com
Had to sell my baby..
2001 White F-250 CC 4 inch lift 325/60/17 MKW
BTS tranny,Hypermax stage 2 injectors,H2E Quick spool turbo,Dp-tuner chip,4:30 gears,AFE stage 2 intake,ITP fuel system,4 inch straight exhaust,Machined and ported heads,Forged rods,Beans Headstuds and other mods too many to name!!!((Sold)))
bagstroke is offline
Old 05-15-2005, 08:48 PM   #2 (permalink)
Re: Heat shield ..Is it ok to remove?? or does it really help your tranny stay cool?
The stealership flunkies even know not to do that.
armchairengineer is offline
Old 05-15-2005, 10:53 PM   #3 (permalink)
Thanks for your input... [img]/ubbthreads/images/graemlins/vomit.gif[/img]
jbgarner12@msn.com
Old 05-16-2005, 11:23 AM   #4 (permalink)
GEM
My Photos: (10)
Maybe the user name says it all [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
What does your tranny gauge tell you? That's what I would go by. I hacked a chunk of the heatshield out to get my Aeroturbine as far forward as possible and I had the same concern. I'm sure there is some heat transfer that occurs (that shield is there for a reason afterall) but I haven't noticed any change with my tranny temps.
GEM
'01 F250 7.3L PSD 4x4 XLT SD SC SWB Harvest Gold, PMT1(stock)/Tipton 4-pos chip(PMT1), Factory Tech Monster Box, Dieselsite trans filter, Tru-Cool, 3.73 LS, camper/offroad/tow, chrome steps, cab clearance lights, Lund deflector, bedliner, Pro Flaps, Warn 9500# front/rear receiver mounted winch, Tekonsha brake controller, 285/75R16 Yokohama Geolander AT+II's, A-pillar w/ISSPRO EV gauges, ISSPRO Turbo Temp monitor, "Hutch" fuel mods, 'Pooned tank, Airdog, open element intake w/Zoodad, ATS housing, CCV reroute, ITP H/X, JNB reg fuel return and supply w/no CVs & restrictors, AD#8, TC lock, power pedal, manual idle, coolant filter, DPPI T409 exhaust w/3.5" DP, Aeroturbine, Tuff Country 2.5" leveling kit & 4" rear blocks <font color="red">www.gmayle.com</font>
<font color="blue"> Colorado Powerstroke Club </font>
GEM is offline
Old 05-16-2005, 11:32 AM   #5 (permalink)
GEM
My Photos: (10)
Bagstroke - I need to correct something. I just went and checked under the truck and the part of the heatshield I removed was farther back, at the transfer case and on the frame side, not the tranny/transfer case side. So, my experience isn't valid, assuming you removed part of the heatshield up by the tranny/cooler lines.
Nonetheless, I would just go by your gauge.
Not that this matters at this point, but what did you have to get to that required you to hack on the heat shield? The top of the tranny can be reached from the driver's side but I've never actually tried to remove and replace anything up there with the tranny in the truck.
GEM
GEM is offline
Old 05-16-2005, 01:14 PM   #6 (permalink)
Sometimes the heat shield protects things like the case or wiring or sensors that can get hot enough to soften. Aluminum doesn't like to see much over 300°F before it's properties start to change. It might not make any difference to fluid temps, but a small spot on the case might have a problem.
Casey_1 is offline
Old 05-16-2005, 01:20 PM   #7 (permalink)
Isn't the purpose of the heat shield to help prevent transfer of the tranny heat to the floor of the cab? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I don't believe it functions as a heat sink for the tranny and if it does I can't imagine that it's a very good one.
"Thinking is the hardest work there is, which is probably the reason so few engage in it." - Henry Ford
"The greatest lesson in life is to know that even fools are right sometimes." - Winston Churchill
"Life is tough, but it's tougher if you're stupid" - John Wayne
2000 F250SD Lariet SC, PSD, 4X4 Offroad Pkg, ESOF, AT, Shorty, Tow Pkg
Smoke Signals is offline
Old 05-16-2005, 02:30 PM   #8 (permalink)
Good point, but there is also a heat shield between the transmission and the exhaust pipe, although I have a manual transmission, but I guess it should be the same for automatics. Aren't the manual tranmissions bigger that the automatics, thus the heat shield? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2002 F-250 XLT,6 Spd,AIS Intake,Air Horns (Hadley Twins),Quadzilla Stealth Module,Oilguard Filter,Starter Security Modification,XM Radio,Autometer Cobalt Gauges,Baldwin Coolant Filter,Edelbrock Shocks,Hellwig Sway Bar (Rear),Fabtech Dual Stabilizer,Custom Running Board Lights,Light of Fire Rear Lights,Diamond Plate Tool Box, Tailgate and Side Rails, AirDog Fuel Seporator with Isolation Mounts, Manual Trans Filter, HX Mod, Maxed out Credit Card. Born in Kentucky, Raised and Modified in New Jersey, Home of "T"
daisy096 is offline
Old 05-17-2005, 12:59 AM   #9 (permalink)
The shield is between the tranny and the exhaust pipe..I have noticed a temp change in my tranny gauge..I was always below 150 and now I'm closer to if not at 180 or higher..So I'm thinking about going over to the dealership(parts)and getting a new one...Believe it or not I think it really makes a difference...Or I might just wrap some heat resistant foil wrapping around the exhaust the length of the tranny? The new shield is $75 so not that big of a deal.. was trying to get to the top of the transfercase where it connects to the tranny...It was a *****..But I'm no expert so I did what I could...O'well live and learn... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
jbgarner12@msn.com
Old 05-17-2005, 01:01 AM   #10 (permalink)
LOL!!!!
jbgarner12@msn.com
Old 05-17-2005, 07:48 AM   #11 (permalink)
Well, I would think that as your moving down the road, there would be enough air movement to keep the heat away. And if your at a light, or idling for extended periods, then the egt's mostly stay around 300 degrees or so, I would think it wouldn't be an issue other than to keep the heat away from the floor board as the other poster suggested.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 05-17-2005, 07:05 PM   #12 (permalink)
Car manufacturers are in business to make money, they don't put things on the cars that you can't readily see that add cost to vehicle unless engineering deems them 100% necessary.
Duh
Old 05-17-2005, 11:57 PM   #13 (permalink)
Duh
Your just full of great opinions...We'll all benifit from your words of wisdom here at TDS.Stick to your armchair.. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
jbgarner12@msn.com
