Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-01-2008, 01:04 AM   #1 (permalink)
Bill1013's Avatar
HELP 150 Mi. From Whitehorse Yukon
7.3 Engine runs OK at above 40 MPH Below that seems like running on one bank. Lots of blue smoke and no power. Changed CPS, no change. Going to Ford dealer in the morning if I can make it back to Whitehorse. Any suggestions appreciated. Internet is lousy here. Might be bad fuel, gave it a big dose of Diesel Kleen, have not run it since then.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Strictly stock. Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB 2WD Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors -New Beru GP's 07/07 New radiator & hoses New WP
Dual Exhaust 3"X18" resonators frnt. of rear wheels
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 07-01-2008, 02:43 AM   #2 (permalink)
My Photos: (15)
If it is fuel that is bad, have any extra fuel filters?
It was almost 20 years ago on my trip through canada that I was having a fuel filter problem with some bad GAS.... (1973 Ford Gal 500 2D) was not fun... made about 150 miles in 12 hours...
Just some thoughts on the matter..
Say hi if you get to Alaska...
The van is back..........(song of elton john... the B.... is back....)
But boy does it need that program.......
"FAILURE IS NOT AN OPTION" 2000 E350 7.3PSD, Hellwig Stablizer bar, Headlight Harness upgrade from: http://www.suvlights.com/ 265/75/16E, 140 Lightforce w/blue, yellow, clear covers. My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
Alaskapsdvan is offline
Old 07-01-2008, 10:40 AM   #3 (permalink)
Bill1013's Avatar
No check engine light comes on. Pulled main connection plug to injectors, looks good there. Would it be feasable to try and clean the fuel filter, I don't have a replacement with me ? This all started after the last fuel up, and driving about 100 miles. Could it be the HPOP ? got about 5500 Mi. from last oil change, oil looks fairly clean on the stick.
Formally OLDBULL
Bill1013 is offline
Old 07-01-2008, 12:26 PM   #4 (permalink)
Gooch's Avatar
I travel through there with a big load every year. In fact just got back. Whitehorse Ford will treat you ok. You may want to call ahead for a slot and a chat with a mechanic to give them a heads up on ordering what you may need. Some things take more time there. Donuts and coffee go a long way with the Yukon'ers.
It sounds like an injection oil pressure problem, or maybe even turbo. Try diconnecting the ICP sensor and see if it runs any better. Definitely drain your fuel bowl and see what you get. Not ripping on you, but you're crazy not to carry a spare fuel filter on a trip like that, and you need to change that oil more frequently when towing in those conditions.
Good luck and let us know how it turns out.
'01 F-350 4X4 CC XLT Auto.
Gooch is offline
Old 07-01-2008, 08:43 PM   #5 (permalink)
Bill1013's Avatar
Thx. Gooch. Will try to get a fuel filter at Napa here in Whitehorse and change the oil tomorrow. Canada day today, nothing open today. ICP ? Injector Control Press. Sensor. I know I should have brought a fuel filter, just left it home, forgot it, got most everything else. 3-CPS 2-Oil filters Serp.belt 2-Air filters etc.
Truck ran fine for a 100 miles back to WH, running at 55-60 MPH, but would load up(fuel) when coasting downhill then blue smoke until 17-20K RPM was acheaved.
Will try the Ford dealer tomorrow. Do you know anything about Horsman Mech. or Inland Kenworth? Anyone else in the Whitehorse area.
Bill1013 is offline
Old 07-01-2008, 11:04 PM   #6 (permalink)
My Photos: (15)
I be still hanging on the fuel filter... simple, cheap. Also your challenge reminds me that I too should be putting in an extra fuel filter for that just incase....
Let us know what you find out when things open up again,,,, not looking forward to this weekend(4th).
Old 07-04-2008, 07:18 PM   #7 (permalink)
Bill1013's Avatar
Well guy's, this was a $600 mistake. Sure could have been a lot more bucks. Filled a half tank (20) gals. with regular gas, unmarked pumps, used the yellow marked nozzle thinking it was diesel fuel as I was doing all along.
If anyone has any trouble near Whitehorse Yukon with there Ford Diesel, DON'T go to the Ford Dealer, contact Horsman Mechanical, Terry really knows his stuff about the Navistar engines. My cost to him was just $20, which included a can of Stanadyne injector cleaner. The rest was oil change Wal-Mart, fuel filters and oil at Napa, campground space over the weekend (Canada Day) holiday.
Thx guys for the support.
Formally OLDBULL
Bill1013 is offline
Old 07-04-2008, 07:55 PM   #8 (permalink)
Toban's Avatar
BILL1013 - Every diesel fuel handle I've used in Canada has always been a green coloured one.
It's a good idea to ALWAYS look at the pump station to make sure it says "diesel" before you plug it into the fuel tank.
Ken
Winnipeg, Manitoba, CANADA
2006 F-250 King Ranch 6.0L Diesel - 4x2 - Stock
I just want to age disgracefully
Toban is offline
