Help!!!!!
heres what i got 02 7.3 and i just put a upgraded compressor wheel in. i did everything myself and it all went smooth until i got the right side of the turbo housing back on and when i went to hook the wastegate rod back up to the pin. the pin wouldn rotate counterclockwise towards me so i could reattach the rod back to it. im stomped i tried it all except tearin it back down because i ran out of time in the shop i was usin. is there somethin i forgot or didn notice i put the housing back on. cause the wastegate will not move and i had to limp it home with the wastegate not even hooked up. didn even get to test the new addition because i had to keep it from boostin please help
02 F 350 Crew cab long bed 4x4 6" Rancho 20" chromes with nitto swampers, straight piped and K&N lookin for more
