Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-12-2009, 11:48 AM   #1 (permalink)
help 7.3 dying
i idle it up to 2000 and held it there for a few mins and it want to die and cut out and then u get back in it and its acts like there is nothin there and then just dies whats this mean i put a new icp in it and its still acting up i clean the ipr
dishpsdpower is offline
Old 07-12-2009, 01:10 PM   #2 (permalink)
tbpower's Avatar
Make sure your oil is full and is not to old and thinned out. This can cause similar problems. Also check fuel pressure. Looks like you had another thread going about the icp. I think your next step would be the ipr. What codes were you reading and what scan tool are you using?
2000 7.3 powerstroke. Air raid cold air intake. AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler.
tbpower is offline
Old 07-12-2009, 02:49 PM   #3 (permalink)
my edge chip and it reading icp out of range low and now its reading cam sensor but it has a new cam sensor in it so i dont know why that would be showin i got to thinkin about the oil and i just ran out and look im about 2,000 miles over ya wow i thought i had 2,000 to go but u think if i change the oil it will work
Old 07-12-2009, 04:02 PM   #4 (permalink)
tbpower's Avatar
I would definitively change out your oil. Address the cps issue before changing out anything else. Your tach should be moving up to about 100-200 rpm's while cranking. It is not uncommon to get a bad cps. You could also have a wiring issue with the cps wires.
tbpower is offline
Old 07-12-2009, 04:57 PM   #5 (permalink)
ok thanks man i check for codes again and now there is nothin its running good but keeps cutting out and dies when u start to drive but iom goin to change the oil and c what that does but thanks i would have never thought of the oil
Old 07-13-2009, 06:20 PM   #6 (permalink)
hey thanks tbpower it lives i have my truck back thanks man
99 F-250 psd 4x4 3"lift on 35" 4" full exhaust edge chip
