Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 09-03-2009, 05:25 PM   #1 (permalink)
remedm's Avatar
Help!! Blackstone lab reports high lead levels AGAIN
My lead levels keep going up big time, What gives!!!!!
I switched to syn with shorter interval and it got worse
I know I went a little long one time and it seems like
ever since then they keep getting worse. Did I damage
my engine by doing that. I have heard of some auxilary
oil filters doing this, Is oilguard one of them, Do I need to
get rid of it. Please help this is killing me. I try my best
to take the best care of my truck.
Take a Look at the report and tell me what you think. PLEASE!!!!!!
D86917.pdf
2002 CC F-350 SB SRW 4X4 TOREADOR RED
DP-TUNER NO-START, MOD STOCK, HIGH IDLE, DRIVE THRU, 40 TOW, DECEL, 60 TOW, 60 ECON, 80 ECON, AND RACE
BTS TRANNY (NUFF SAID) ; 6.0 COOLER
DIESELSITE BOOST RELIEF VALVE, 203^ THERMOSTAT AND HOUSING, MAX A/C VALVE AND COOLANT FILTER
ATS TURBO HOUSING, FORD A.I.S., OILGUARD BY-PASS, 4" MAGNAFLOW STRAIGHT PIPE, SIDE EXIT,
NCHORNET'S CCV MOD, POR-15 OIL PAN
ISSPRO A-PILLAR PYRO/BOOST/TRANS, ISSPRO ENGINE, OIL TEMP AND VOLTS OVER MIRROR
MARINCO MOD, LED ID BAR, HEATED SIGNAL MIRRORS, LED BRAKE AND TURN SIGNAL BULBS FRONT AND REAR
RHINO BED LINER, SIRIUS RADIO ,
AMERICAN EAGLE WHEELS WITH 305-70-16 NITTO TERRA GRAPPLERS WITH A 2" DONAHOE LEVELING KIT
TRUCK BUILD DATE 1/8/02
BTS BUILD DATE 1/8/07 AT 41K
My Truck
remedm is offline
Old 09-03-2009, 06:41 PM   #2 (permalink)
Got Diesel?'s Avatar
Well all I have to add is I noticed you were using 5-40w Rotela, I swear by the Shell oil but I did notice I use more oil when I switched to the lighter weight....as to the lead...I got nothing for ya bud....Good Luck??
2000' F-350 Reg cab 4x4 Plow truck- 8611lp Blizzard plow, FTVB, DP Tuner,
2003 Mercury Marauder
1989 Mustang Coupe- Drag car 10.96@ 126
Got Diesel? is offline
Old 09-03-2009, 08:30 PM   #3 (permalink)
remedm's Avatar
Should I switch back to the heavier oil. Is there more detergent in the
syn oil and cleaned some stuff out on this round.
FYI I switched to shell syn on this go around and it was the
worst report I have had with less miles!!!!!
My Truck
remedm is offline
Old 09-03-2009, 09:13 PM   #4 (permalink)
Very interesting stuff....I don't know the answer to any of your questions
I run the Shell syn because of the low viscosity for our cold Minnesota winters, extended drain intervals and the cheap price.
I'll be watching to see what other have to say
Old 09-03-2009, 09:31 PM   #5 (permalink)
Wear metals almost always go up when you switch to synthetic. If you want to lower them switch back to dinosaur juice.
444-4D is offline
Old 09-03-2009, 10:10 PM   #6 (permalink)
remedm's Avatar
444-4d Why is that, The truck acts so much better with the syn.
I am going back to 5000 mile on a change, If the lead is still high
on this one with the syn at 5k then Im going bact to the cheep
stuff (shell 15-40) Cause I was only a little high with the cheep stuff
evan above 7k, So I would think at 5k EVERYTHING will be in spec.
I am very confused I would have bet money my blackstone would
have been next to perfect this time.
I just cant live with being double the average on lead just to get
smoother starts in the winter. I will just go back to pluging it in
at anything under 25 degrees.
This is just absolutly driving me INSANE..........
Time for a Beer or 2 or 3 maybe even 12 at this point.......
My Truck
remedm is offline
Old 09-04-2009, 12:11 AM   #7 (permalink)
goatherder's Avatar
Tell your wife to put unleaded in it
goatherder is offline
Old 09-04-2009, 08:55 AM   #8 (permalink)
444-4d Why is that,....
What possibilities are there other than "it doesn't lubricate as well in this application"?
444-4D is offline
Old 09-04-2009, 09:40 AM   #9 (permalink)
That goes against everything that we're led to believe....
Old 09-04-2009, 11:35 AM   #10 (permalink)
That depends on who you choose to follow. It doesn't go against what I'm led to believe.
444-4D is offline
Old 09-04-2009, 11:43 AM   #11 (permalink)
klhansen's Avatar
My Photos: (107)
It may not even be related to the oil choice.
If a bearing starts wearing and throwing lead into the oil, that bearing probably isn't going to heal itself. My guess is that lead will continue to increase no matter what oil is used. Higher viscosity may help to reduce lead iniitially, but it will probably continue to increase and eventually (probably not tomorrow) that bearing is going to be bad enough that the engine will need to be rebuilt.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 09-08-2009, 03:12 PM   #12 (permalink)
remedm's Avatar
That is what I didnt want to hear!!!!!
My Truck
remedm is offline
Old 09-08-2009, 03:27 PM   #13 (permalink)
klhansen's Avatar
My Photos: (107)
It may not be all that bad. I wouldn't worry over it too much, but keep looking at your UOA numbers. Like Blackstone said 14 ppm lead isn't huge in the big picture, but you just want to watch for trends or an accelerating concentration of lead.
Blackstone did mention the possiblility of it being caused by WVO, if you're using that. I once had a smaller spike in lead that they attributed to a particle getting stuck in a journal and causing a "lead smear". I do know that you can run for a LOOOOOONG time with scored bearings without major issues.
klhansen is offline
