A friend has a 2002 F350 and had an event last night. Driving down freeway and it died. Pulled over and tried to restart. Would restart but only ran for approx 20-30 seconds then died again. A friend towed him home but now looking for a possible cause. What should we look at?
1997 F350 Crew Cab 4x4, AT, 4.10, drivetrain is all stock. Toyo Open Country A/T 285/65-18 10-ply on Allied Renegade wheels. Snugtop shell. TYMAR Intake. Coated H-Max DP with 4" exhaust. Donaldson resonator and Cat had to be put to sleep. Just turned 58,000 original miles!!!! Best addition-Wildman chip- Phantom II gauges. Sonnax valve w/ Tri-C springs and Royal Purple in the trans with a supplemental fan on the Tru-Cool cooler. ATS intercooler with 1.0 turbo housing and clean pedestal, no EBPV. SuperSprings installed.
He changed the CPS. Same issue. What's needed to check fuel pressure? Also, where is fuel cut-off switch and what's its purpose, aside from the obvious? What's required to check oil pressure?
Thanks for the help. I have to relay info to him until I can go over to help.
You can check fuel pressure by hooking up a 4' fuel line (5/8"??) to the drain tube that comes down the front passenger side of the engine. Secured by hose clamps on both ends with a fuel pressure gauge (at least 60psi) at the other end. Open the drain valve on the fuel bowl and turn the key over. The fuel pump will run for a minute before shutting off. Should have at least 45-55psi. Where is the fuel level?
But before doing all of that, just empty the bowl and see if it fills up.
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes (Stock, 40 Tow WITH Whsiper tune, 80 Daily Driver, 100 Race, 140 Extreme, 140 smoke show)//Recon smoked cab lights/MM Hubs/Hood/HPx/FRx/GPR switch-Indicator
First vehicle (still driving): 96 F250 XLT 2x4- All factory (injectors & turbo) except straight exhaust. 570k miles
Will pass on the info. Thanks for the help, again. Will update as soon as we can.
Is he using a chip or programmer? If so that should be pulled first. If not running a chip, the cps and fuel pump switch are next easy suspects in line to check.
On the electrical side, are the batteries in fine shape. Slightly low/weak batteries may briskly crank the engine but have insufficient voltage to allow the computer to function, especially now that weather is in general colder.
Lake Norman at Denver NC 1999 250 PSD (built Sept 98) Lariat XLE7 CC Auto LWB 4WD ESOF ABS 3.73LS X-Caliber cap BFG 285E AT/KOs Jayco-TT 31BHS
He was already running, so cold batteries shouldn't be the problem and theoretically the battery light should come on if there is a battery/alternator issue.
Just remember to start with the little stuff first and work your way up.
Sent from my DROID RAZR using AutoGuide App
*** "He was already running, so cold batteries shouldn't be the problem and theoretically the battery light should come on if there is a battery/alternator issue." ***
If batteries go below the threshold to keep computer happy, when you drop off engine speed such that you are running off the battery instead of alternator, the computer can shut you down. And the batteries may not have enough juice to fire it back up.
The dashboard indicators do not typically kick in unless there is a major problem, not just slightly lower than desired alternator output or slightly low voltage.
I have had to replace my batteries twice to date, and never have seen an indicator turn on for this. But this did keep the engine from running until replaced. Hey I am not guaranteeing either is his problem, just saying that these are definitely potential causes, and quick and easy and cheap to eliminate or confirm. Cheers!
Update. No RPM while cranking but will register when it does start. Will not restart immediately after it dies. Has a DP-Tuner chip and will be pulling it. Crappy weather so not able to work on right now. He will be checking fuel pressure at bowl. Changed the fuel pump about 1 1/2 years ago. Had fluctuating low pressure. Replaced with a Napa pump. He did say a relay was chattering under the dash when key on. Hmmm, does this help with a diagnosis?
You're draining the battery by constantly trying to start the truck without charging it back up, so when the battery voltage drops (under 10.5v I think), that relay opens back up, so a chattering relay indicates your batteries are right at that 10.5 threshold.
How far is the oil from the top of the HPOP reservoir? Should be about 3/4 of an inch or so.
1999.5 F250 creeping up on 400k.
He is picking up a pair of batteries today. Haven't heard if he has been able to check out levels or pressures.
