help please - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-19-2012, 09:40 PM   #16 (permalink)
alaskan powerstroke's Avatar
ok im new to the deisel thing, im a hot rod guy, with that said is this a stupid question lol whats the difference between a programmer and a chip? a local guy here said i can stack the plug in banks 6level chip with my edge cs programmer. Is that safe or can it damage anything?
alaskan powerstroke is offline   Reply With Quote
Old 11-19-2012, 11:58 PM   #17 (permalink)
klhansen's Avatar
My Photos: (175)
A programmer flashes its program on to the PCM, exchanging the stock program into the programmer.
A chip plugs on to the PCM and causes it to use the program on the chip instead of what's on the PCM.
I don't think you can "stack" a chip with a programmer, because the chip's program will replace what the programmer has installed on the PCM.
You can stack either a chip or a programmer with some of the devices that install in the sensor (such as ICP) wiring. They change the signal going to the PCM.
Hard or no-start? Check Here
Old 11-21-2012, 12:20 PM   #18 (permalink)
tattoocharlie's Avatar
My Photos: (5)
the waste gate is blocked to allow higher boost,that way the pcm doesntr read the boost level and defuel.
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline   Reply With Quote
Old 11-21-2012, 12:32 PM   #19 (permalink)
so in my programming for the juice i should turn defueling off? i think a lot of this chip not giving me the results i want is do to me not knowing what the f im doing lol. and not tunning this right. I was under the impression that if the waist gate is left open it would push the heads off this thing.
Old 11-29-2012, 12:06 PM   #20 (permalink)
hey, im going to change my t case oil, any suggestions or instruction. roughly how many quarts and whats the best to use. 2000 f350 with 7.3L believe its a 4 speed auto, dash say 1 2 and 3 with overdrive around 3. lol if that makes since
Old 11-29-2012, 05:28 PM   #21 (permalink)
klhansen's Avatar
My Photos: (175)
The t-case takes about 2 quarts of ATF. You should use a good quality ATF or even synthetic ATF.
Be careful when you pull the lower plug out to drain it. It's aimed toward the back of the truck and will spurt out about 2' before it hits the ground. Make sure you have your drain pan positioned correctly. (Don't ask how I know that ).
The manual and automatic trannies use basically the same t-case.
Old 11-30-2012, 08:15 PM   #22 (permalink)
lol so you werent lying aboyt the 2 foot thing. almost got me lol thanks for the help, previous owner didnt change or upkeep anything, oil was black and there was maybe a quart. same with the rear diff, low and nasty, trans was black and filter looked like it had gelish gew on it. air filter was so plugged and dirty that it was half collapsed. thing is runnung awesome now that all the fluids and filters are done, added the edge chip and banks exhaust with down pipe, ive gained 7 miles to the gallon and everyhting shifts perfect and runs excellent... im pumped. thanks everyone for the help......
Old 11-30-2012, 10:15 PM   #23 (permalink)
My Photos: (35)
Good to hear that you have turned a sick and ailing truck and get it well again.
It does show the NEED for the changes that you listed.
2000 E350 7.3PSD, Hellwig Stablizer bar,140 Lightforce with covers, 55Watt High/Lows HID's (watch which company) , extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E Toyo Open Country, My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline   Reply With Quote
Old 11-30-2012, 11:40 PM   #24 (permalink)
klhansen's Avatar
My Photos: (175)
Originally Posted by alaskan powerstroke View Post
lol so you werent lying aboyt the 2 foot thing. almost got me lol thanks for the help.
I would NEVER lie about something like that. Glad you got it squared away without having to clean up a mess.
Old 12-01-2012, 09:35 PM   #25 (permalink)
Thumbs up
yes indeed, todays project was the rear driverside calliper and rotor, the rotor was worn so bad that the smooth part was gone and it wore into the center splines of the rotor, no smooth surface left. it almost looked as if someone put it back together without a pad. unbelievable, it ripped the back piston right out of the calliper, dumped the brake fluid and lost brakes while i was backing my flat bed into the driveway, just ten minutes before that i was towing an extended cab 3/4 ton chevy in the snow threw the hills with the family in the truck. imagine if it would have blown then. kind of scary... on a good note my new profile picture i tool today before the tow would make a ford commercial as the chev sits on my trailer like a rock lol
