Help Please Speedometer problem - Diesel Forum - TheDieselStop.com
Old 11-08-2009, 11:21 PM   #1 (permalink)
I am new here but I need help
I have a 01 f-350 ext cab 4x4 7.3 auto
The speedo wasnt working until i got to 40 mph, and the abs light was on.
Well I replaced the vss and the speedo works now until i get to 40 mph and it wont go any farther, but the truck runs fine.
I recently changed tires from 315/75/16 to 285/75/16
I also replaced the inner-tie rod.
Before i did all this the speedo would work after 40 mph but not before it got to 40
also the o/d light does not come on
I am leaving for deer camp in 6 days, and want to fix this, or i have to use the gps for speed
richemmers is offline
Old 11-08-2009, 11:45 PM   #2 (permalink)
woodnthings8's Avatar
Your speedo gets its signal thru the ABS module, it gets signals from the rear vss sensor. If you have an ABS light you probably have other issues.
You o/d light can be burnt out, does it shift into o/d and can you cancel it with the button?
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 11-08-2009, 11:48 PM   #3 (permalink)
the abs light went out as soon as I replaced the rear speed sensor (vss)
Old 11-09-2009, 12:03 AM   #4 (permalink)
Here is what the manual says about the speed signal;
The instrument cluster is hardwired to the four wheel anti-lock brake system (4WABS) module. The instrument cluster micro-processor monitors the VSS data from the 4WABS module and commands the speedometer with a corresponding movement of the pointer. The vehicle speed signal is generated by the rear anti-lock brake sensor and sent to the 4WABS module. The 4WABS module sends the vehicle speed signal via circuit 679 (GY/BK) to all systems that require a vehicle speed signal input.
Ken
TSB Information
