Help with Replacing LIFT PUMP - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 09-30-2008, 04:15 PM Thread Starter
Browning01's Avatar
The dealership tells me my issue is my lift pump. They want 680 total for the pump and install. I ordered one from advanced auto for 179 and Im going to do it myself. I know where it is located, on the frame rail under the drivers seat. Besides the fuel line tool, do I need anything else to remove it and install a new one? How exactly do I do it? Do I need to buy more fuel line or anything? thanks in advance
2001 F250 7.3L White 4X4, Lariat Crew Cab, 7 1/2" Superlift, Mickey Thompson Classic lock Wheels wrapped in Dick Cepek 325/80/16 tires, 05-07 Grille and Headlights, wood dash kit, Pioneer Flip out DVD player, Cobra CB mounted under the 4x4 switch, DP-TUNER WITH STOCK, NO START, 80 ECON and 140 AGRESSIVE, DIY Intake with napa 6637 filter, IC Foil delete, new aftermarket tranny with sonnix shift kit and triple disc billet Torque converter, 4" Magnaflow Turbo back exhaust, Plantdrive wvo kit with 75 gallon external L shaped heated tank in the bed, Racor filter inline before the stock one, 146,000 miles
Browning01 is offline
post #2 of 12 (permalink) Old 09-30-2008, 06:16 PM
klhansen's Avatar
My Photos: (180)
Assuming it's the proper part, all you need to do is disconnect fuel lines and power connector, unbolt the old one from the frame, bolt the new one in place, and reconnect fuel line connectors and power connector.
), AIS,
regulated return,
klhansen is offline
post #3 of 12 (permalink) Old 09-30-2008, 07:07 PM
The factory replacement FUEL pump is way easy to change as it pretty much just bolts and plugs in.
I would not say the same for an aftermarket one as you probably are required to reuse the mounting bracket, some fuel lines and the wiring harness. In either case you will need a fuel line disconnect tool, not sure what size so you might want to just buy the set. Not too pricey and yes the cheapy auto parts store ones work just fine. if the truck is real dirty under there it might be good to pressure wash the area around the old pump first.
early 99 F350 4x4
DieselDeaf is offline
post #4 of 12 (permalink) Old 10-01-2008, 08:47 AM
real easy with fuel line disconnect tool....but i just went thru this and if you have access to some air blow back thru line going to the tank turned out my old pump was good the two filters in the mixing chamber was clogged,,,,,,,,,but maybe its just your pump....later
kspence101 is offline
post #5 of 12 (permalink) Old 10-08-2008, 06:53 PM
Banned
Dont. That pump is JUNK. Mine lasted 300 miles. The problem is that its a modified gasoline pump, and diesel has a different electrical resistance than gasoline (yes, the commutator brushes run bathed in fuel in most fuel pumps. I dropped my teeth when I discovered that - seems like we'd see these things bursting into flames on every corner...)
Spend the bucks and get the higher-priced Bosch pump available from AA, which is a direct OE replacement (the original pump was made by Bosch). Its also easier to install than the lower-priced hack job.
Alabamatoy is offline
post #6 of 12 (permalink) Old 10-16-2008, 07:45 AM
Steve250's Avatar
I am about to tackle the same project and I am wondering what the fuel line disconnect tool is and where I can get it?
Also, should I expect fuel to come gushing out when I disconnect the lines?
BTW, I'm doing it on an IDI... is the pump going to be in the same place as the PSD was?
Thanks so much!
'92 F-250 7.3 IDI Diesel 4:10 (99k) 4x4 ext cab (Prodigy brake controller
'98 Ranger 4x4 ext cab - wheelin' in the mud
John Deere 510D Backhoe - it's not a ford, but it's nice
Steve250 is offline
post #7 of 12 (permalink) Old 10-16-2008, 09:19 AM
bugman's Avatar
My Photos: (12)
Thanks so much!
You may want to post this down in the IDI forums. The 99+'s and the IDI engines are two different animals.
Jim
bugman is offline
post #8 of 12 (permalink) Old 10-16-2008, 11:15 AM
Steve250's Avatar
Ok, I'll do that.
Steve250 is offline
post #9 of 12 (permalink) Old 05-02-2009, 08:43 PM
does anyone have a photo of a fuel line disconnect tool? i'd like to know what it looks like before i go to the parts store.
thanks,
johnnieboy
2002 green, f250 crew cab, lariat, 3.73, 4x4, linex, cyclone fan, bfgs 285/75 r16, isspro ttm, a.i.s intake, in tank/pre pump, racor prepump 30 micron filter, ad injector in #8, itp fuel regulator bypass,fuel cooler, titan 12000# hitch, aic, 3 gauge a pillar pod, magnefine filter, vandal alert, speed radio, stull grill, tru cool max tranny cooler, snugtop extra vision, banks monster exhaust
johnnieboy is offline
post #10 of 12 (permalink) Old 05-02-2009, 09:10 PM
klhansen's Avatar
My Photos: (180)
Check here for what they look like.
Fuel Line Disconnect Tool Set OTC7361
Most parts places will have a set with a range of sizes for $5-$10.
), AIS,
regulated return,
klhansen is offline
post #11 of 12 (permalink) Old 05-05-2009, 02:15 PM
Just did this on Mama's Ex, and at first I bought a aftermarket.
When I pulled the old, and compaired it to the replacement I boxed it back up, returned it and sucked it up for the Ford unit. There just wasn't any polishing that turd.
T'was the right choice for me, your mileage may vary.
2001 CC Dually 4X4 LWB PSD 3.73:1
CCV Mod AIS Sleeve BTM DP Tuner
2000 PSD Excursion Limited 4X4 CCV Mod
2005 Ameri-Camp F321QBS-BS
19' Sea Ray Pachanga
landcbrewer is offline
post #12 of 12 (permalink) Old 05-05-2009, 08:01 PM
thank you very much!
