Help! A strange alarm sound coming from under the dash!
Just hopped in ther beast, started it up and backed into the street and a buzz type alarm started sounding under the dash by the fuses. Thought it seat belt or something---pulled back in and shut off but it wouldnt stop!! I had to pull the battery cables to stop it. Not that loud,,cant hear it from outside but a constant sound , not on and off. What the heck! Im afraid its some type of big warning and I have to go to work tomorrow. Thanks.
2001 F-350 Lariat,CC,LB,SRW,4X4,Auto,7.3,2"lift,KYBs, 3.73, steel oil x-over, aFe Stage II Pro 7, AirCond mod, Fumoto, DP 60,80,100. AIH Delete, hi-lite/fog-lite on mod. Dead bird in grill. Part of finger in new ball joint nut.
Sounds like a relay that's buzzing (switching on & off quickly). This happens a lot with trucks that have a leaky windshield. Was it recently raining? May even be a GEM that's causing it. Did you notice anything turning off/on or any flashing lights?
2002 F350 XLT, CC, SB, 4x4, Auto, AIC, DiabloSport Predator, BD X-Monitor, Kenwood TM-V7A, Pioneer 7400MP3, Infinity 5.25" Components, Infinity 10" Sub in a Q-Logic Box, Heated Mirrors, Gentex/Mito Auto Dimming Mirror, Rear ID Bar, Uniden PC78 Elite CB, Clifford Matrix RS3 Alarm/Remote Start, Keypad Entry, Homemade "Tymar", custom, muffler back exhaust, 6 Whelen LED's in rear window, 6 Whelen Strobes in the Front, Rears still not installed...
Its not a buzz more like a seat belt type beep that is constant. A constant note, not beaping, right in fuse panel area. No other strange activity at all and the truck ran OK but Im afraid its some sort of warning and I shouldnt drive it. Do we have anything like that in these? And, it wont stop even if the truck is off. I think it actually was in the fuse box. lower left of steering wheel
Just spoke with FORD and was told they had never heard of that before. Comforting, eh? He guessed that it could be a stuck relay and said I shouldnt try to drive it because the relay could cause a fire. So now I have to pay $150 for a tow and Illbet the mechanic simply pulls out a relay and slaps another in. Two minutes work will be $1,455,686.02 and $500 for a $15 relay plus tow. I had planned to retire but not now.
If it's the seat belt chime sound, that would be coming from the GEM. Possibly the door switch/key-in-ignition dinger. I din't think it would hurt to drive it, except for your nerves from the constant dinging.
Try messing with the door switches (the WD40 trick) and maybe disable the key-in-ignition switch and see what happens.
Pull the turn signal relay. I think it's' blue and to the left of the radio. May be able to see it if you remove the cover below the steering wheel. Sounds like the noise mine made when the signal relay went bad.
__________________ LED running lights below doors for turn signals, marker lights, and courtesy lights from JadSolution
FOKISD (Ford, Ohio, Kentucky, Indiana, Super Duty Club), Charter Member.
2001 F-350, PSD, 4X4, True Blue, 152 WB, SRW, Auto Trans, Manual Hubs, PMT3, Off Road Package, AIC, Heated Excursion Tow Mirrors w/cut off switch, Extang Tonneau Cover, Westin Step Bars, Lund Bug Shield, Nifty floor mats, Custom rear bumper/w fog reverse lights & 3rd brake light, LED running lights below doors, Poron USA reverse backup sensors.
"It's mine,ALLLLL mine, (Till Andrea wants to drive it)"
It wasnt a chiming or beeping---wasnt irregular. It was a consistant note like if you held the key down on a morse code key. It didnt waver and wasnt very loud. All I could tell was it seemed to be in or at rear of fuses. but the strange thing is it kep it up even with the key switch off? How could anything in the fuse box keep going with no key on?
Today I re connected the batteries and its gone. God only knows.
