Help!!! truck wont crank...bad key - Diesel Forum - TheDieselStop.com
Old 12-14-2009, 02:58 PM   #1 (permalink)
Yep just like the title says i tryed a copy key and now the truck wont start.
Please tell me i dont have to tow it.....
2000 F-250 7.3 PSD superchip, intake, straight pipe exhaust, 6 1/2 procomp lift 37" procomp tires
Hammer450r is offline
Old 12-14-2009, 03:17 PM   #2 (permalink)
tattoocharlie's Avatar
My Photos: (5)
unfortunately your prob gonna have to(unless you have a good spare key laying around)
who cut the new key?and i wonder why you needed a new key cut?lost key?stolen recovery?bad key cylinder?
i worked for a chevy dealer for awhile we cut keys from codes all the time,but,we always checked them before the customer left.
a little more info on your EXACT problem would help
2002 f250 lariat 7.3 200k(motor has 170k)
original 4r100 tranny....200k and counting
knock on wood......
tony wildman chip......
stock,economy,daily,towing,extreme,smoke.
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
Old 12-14-2009, 03:20 PM   #3 (permalink)
ok sorry i bought my truck with 1 key and have had only 1 key for the last 2 yrs.
While i was at home depot i got a spare cut for just in case.
Can i take my good key to ford for a copy?
Old 12-14-2009, 03:23 PM   #4 (permalink)
i just tryed the spare to see if the copy was correct and now the truck wont crank at all even with my good original key.
Old 12-14-2009, 03:30 PM   #5 (permalink)
My Photos: (5)
key
ok...so your ignition cylinder is not turning correct?or is is turning and the starter is not turning the motor over?
im sure ford has the same system that chevy uses,they can cut keys from your vin(assuming the cylinder hasnt been changed).call ford and see what they need to do that,chevy required id and registration.(to ensure the key was for your vehicle)
knock on wood......
4" exhaust no muff
Old 12-14-2009, 03:58 PM   #6 (permalink)
everything works except it wont crank
glow plugs light and go off just fine
Old 12-14-2009, 05:01 PM   #7 (permalink)
Ok in case this happens to someone else thats reading this. Dont listen to Ford just let the truck sit for an hour or 2 and it will pop back out of safe mode on its own.
