high egts- what is to hot! - Diesel Forum - TheDieselStop.com
Old 07-06-2009, 02:29 PM   #1 (permalink)
when i am towing my sleds or my camper here in the mtns of wy, i get fairly high egts. when i pull a hill it jumps from 800 to 1200 degrees. Is it ok to run 1200 degrees for a period of 2 minutes or is this to hot? Just replaced my turbo with a Gillett Diesel service Ball Buster. it has a bigger shaft, bigger comp wheel and .84 housing. turbo is great with just a little whistle and no surge!! wondering what save egts are. thanks-
2002 f350 4x4 CC SB, automatic, tymar filter, 4" exhaust and DP tuner F5 and gilette diesel service ballbuster turbo with 1.00 housing, 285/75/16 tires 102,000 miles
reevs is offline
Old 07-06-2009, 02:39 PM   #2 (permalink)
woodnthings8's Avatar
I pretty much will let off when the needle starts going to 1300. I have read that 1350 for a "short time" is ok, no nobody has really determined short time, but I would say less than a minute. Personally I try not to ever go past 1200. Pulling hills with a tuner and a load really drives up the temps. What tune are you running?
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 07-06-2009, 02:49 PM   #3 (permalink)
tymar intake, 4" exhaust, DP tuner 40 tow mode, climbing from 7400 ft to 9900 ft.
reevs is offline
Old 07-06-2009, 03:04 PM   #4 (permalink)
At that elevation I can see getting high EGT's, Are you having to let off or does it stay around 1200? You might consider a water/meth injection system. And one other thing to think about is your intercooler, if you haven't done the CCV mod you could have restricted flow from the oil in the cooler. I don't know how much it effects it but every little thing helps.
Ken
TSB Information
Old 07-07-2009, 09:17 AM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
The International and Ford engineers that developed the 7.3L PowerStroke engine told us you can run all day at 1,200° pre-turbo EGT, but 1,250° is the red line. Don't let it go over 1,250° for more than a few seconds.
The members of TheDieselStop had a national rally at the Ford Kentucky Truck Plant (KTP), and part of the rally was a bull session with the International and Ford PowerStroke team of engineers. So we heard it from the horse's mouth.
Of course, some folks don't care what Mama don't allow, they'll play their banjo anyhow. So some gamblers use 1,300° as their red line. But of course if they melt a piston they probably won't come back here and brag about it. So I haven't heard of any disasters of running a bit over the 1,250° redline.
With my 60-tow tune and grossing 16k, I have to worry about exceeding 1,250° EGT only for very long grades over about 7 percent and going faster than about 60 MPH. Under those conditions, I'll be downshifted into direct drive and turning about 2,600 RPM. If the EGT gets up over 1,200°, then the cure is to back out of the go pedal just a hair to maintain between 1,200° and 1,250°.
I can't imagine exceeding 1,250° with the 40-tow tune, but I guess if your trailer is heavier than mine,then you could have that challenge. The only time I've use 40-tow (as a test to be sure it worked) , I was grossing only about 13k, so it didn't even get near 1,200° as I crossed the Rockies. (I didn't order 40-tow, but Jody threw it in when he flashed my Evo with DP-tuner tunes.)
SmokeyWren is offline
Old 07-07-2009, 10:26 AM   #6 (permalink)
So, is there any possibility of getting over 1250 without towing and with a 6-speed?
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
Old 07-07-2009, 10:56 AM   #7 (permalink)
Flywheel's Avatar
My Photos: (6)
Depends on your chip and how you drive - assuming everything else is in good working order.....
A stick can hit 1250 as easy as an auto....
Some chips will hit 1200 fast during heavy acceleration empty, other chips will not....
99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, DS Boost Relief, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F5, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand Bumpers, Original Cup Thrower, B&W GN Hitch
Autoenginuity
Flywheel is offline
Old 07-07-2009, 06:47 PM   #8 (permalink)
No chip. All stock except for the AIS Heavy Duty air intake and filter.
Old 07-07-2009, 06:56 PM   #9 (permalink)
CSIPSD's Avatar
My Photos: (52)
Stock, nope, not unless something is broken. Ford and IH make the trucks more or less idiot proof in stock form.
05/01 F-250 PSD,200k,AFE2 ,Modded H2e, 6.0 IC,Water Injection, AIH delete, Swamp tuned, GTS Hybrid injectors, ITP Fuel system, Studs, 910 valve springs, Suncoast 4r100,MBRP Duals, 6" tips, 17 Isspro Performax gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
CSIPSD is offline
Old 07-07-2009, 07:18 PM   #10 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
How about the ebv valve removed and running an open one from dieselsite, also a 1.00 housing should be better than a .84, I assume you already have your exhaust done from turbo down. I believe a water/meth. injection as noted will really be the best thing along with some of the other mods. 6.0 intercoolers not that expensive either. I believe the way our CCV was designed, we all have that slugde all over the intercooler and pipes....should delete it and clean everything afterwards.
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-13-2009, 05:06 PM   #11 (permalink)
I fixed mine this way
I would hit hi EGT's too - towing 15k with a superchips, 4" back, AFE etc.
Well I changed my up-pipes. Guess what - I have not hit 800 degrees in 6 months. Before the change - all that exhaust NOT going to the turbo, makes the turbo work harder (spinning faster) and the EGT's would hit 1000 in no time. Since the change - easy brezzy.
2002 F350 1 Ton Dually LBed Crew Cab
Banks Turbo Back 4" / Banks Gauges
AFE Stage 7 Intake / Trans Go Shift Kit
Superchips Programmer / Mag Hytec Trans Diff Pans
Amsoil Cetane Boost and Diesel Additive
ebham is offline
