High performing filter media for stock air cleaner housing
Does anyone know of a better than stock air filter media for the stock 7.3 air filter housing? Looking for a replacement filter than performs and breathes better than a stock filter which fits within the stock filter housing. Any info and where to get them would be appreciated.
2000 F-350 7.3 2WD 6 SPD XTRA CAB. 3.73 Limited Slip. Edge, ITP in tank w/filter, EBPV delete, CCV, dirt cheap Wal-Mart seat covers
2005 TDI Jetta GLS 5 SPD
1971 K5 Blazer 350 w/350 auto trans.
1972 GMC Jimmy 400 CID w/3 speed man trans, 3.73
1967 Mustang coupe, 289 CID, 4 speed manual.
If the truck is stock like in your sig, the Motorcraft filter can't be beat. Plus you won't have to worry about the filter not fitting correctly in the housing like some aftermarket filters and dusting your motor.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
Agreed. You can't beat a stock Motorcraft paper air filter for performance in th stock airbox. But the stock airbox is a disaster, especially after this many years, so replace it with an AIS.
There is a filter that is better than the one that came in your 2000. It is the filter for the later model trucks. The Motorcraft part number is FA-1750.
Same exact dimension and fit? Did they switch to a different media type or design of some sort?
